Author Topic: Analyzing FLASH - Address does not point to reset_handler, but program works?  (Read 728 times)
Offline eTobeyTopic starter
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
What i learned is, that the first adress in a FLASH program is loaded into the SP. Then the next address is loaded to the PC, which points to the reset_handler that will be executed.
But when analyzing the memory, it does not match.
Its an STM32G431RBT6 and i use CudeIDE 1.12. And the data is from the memory while debugging, and from the buildanalyzer
I am confused.
« Last Edit: December 22, 2023, 04:38:51 pm by eTobey »
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
SDS800X HD bugs/issues/workarounds (Updated 17. Feb. 2025)
Offline ataradov
    • Personal site
It should match, make sure that the Reset_Handler function is what actually in the vector table.
Also, since bootloader is mentioned, make sure you are not confusing bootloader and the application.
Alex
I think i found my problem: A problem that is really annoying.
I use Cube IDE, aka eclipse, and if you change the configuration, then "build" will build the current configuration, but the launch button will have the old configuration still in it.   :palm:
Online DavidAlfa
Yes, build twice or right-click on the project / refresh.
