Hi all,
this is clearly meant to be a question, and I expect some opinions (many) but hopefully also some facts. Especially, please keep it civil between comments!
The motivation for this: it seems LwIP is the de-facto TCP/IP stack used for any application where data (up to 100MBps) has to be exchanged between a PC and a µC. It makes sense in my view, Ethernet is fast and has gone a long way. Micros are capable of handling data shuffling, so in theory it shouldn't be a problem. On the other hand, in the last few weeks we've seen some threads about how to get LwIP to transfer actual streams of data, fast, between a PC and a µC and the difficulties involved, especially regarding lack of information or documentation.
Are there today any viable alternatives to LwIP that are open source, documented and do work? I've seen FreeRTOS + TCP mentioned, but I have not used it myself. Is LwIP dead or is it still being developed? Does someone know? Like someone else mentioned, it seems the latest information is always from around 2002 to 2011, and any search seems to bring up the same results.
I've been able to use LwIP with several ports, both UDP and TCP simultaneously, on F7 and H7 chips, but only to send data to a PC, which then takes care of the processing. I suppose the H7 would be able to do some pre-processing if required, but I never tested that. The fact that STM32 cube integrates it makes it very comfortable as a starting point.
Cheers,
Alberto
