What i learned is, that the first adress in a FLASH program is loaded into the SP. Then the next address is loaded to the PC, which points to the reset_handler that will be executed.
But when analyzing the memory, it does not match.
Its an STM32G431RBT6 and i use CudeIDE 1.12. And the data is from the memory while debugging, and from the buildanalyzer
I am confused.
