Author Topic: Any MCUs out there with good ADC and a USB connection?  (Read 2851 times)
Offline Esposch T. TapirTopic starter
« on: March 23, 2015, 04:54:53 am »
As the title suggests, wondering if anyone knew of a decent micro with both a fast ADC and USB modulator.
Ideally would have a multi-channel 500ksps+ ADC, plus on-chip USB (12Mb/s full speed), a DAC or two and a PWM.
I've looked around and the PIC32MX series stands out.  It has all of the features I need and costs about US$1.50 in 5k quantities.
Does anyone know of anything a bit cheaper/faster/better, though?  Or am I really not going to get much better than that?
Cheers,
~Chris
Bachelor of Engineering (ECSE) with Honours.
Every time I write a line of code or build a circuit I am reminded that, in the grand scheme of things, I know bugger all.
Offline marus25
Re: Any MCUs out there with good ADC and a USB connection?
« Reply #1 on: March 23, 2015, 05:38:30 pm »
I'd look into the STM32F3 series, the STM32F303 line in particular.
Cortex-M4F core with up to 512 kB Flash and 80 kB SRAM. Seems to hit all of your points (and then some)
- Up to four ADCs (depending on particular chip) each capable of running at 5 MSPS (you can do up to 18 MSPS interleaved using one with all 4 ADCs)
- Up to 2 12-bit DACs
- Up to 10 16-bit timers and 1 32bit timer for PWM outputs
- USB device
Also - STMs devices tend to be relatively cheap compared to some others; and have cheap development boards (Nucleo and Discovery series)
Can be programmed with gcc;
Offline Rasz
    • My random blog.
« Reply #2 on: March 23, 2015, 07:50:04 pm »
LPC4370 does 12bit 80Mbit ADC + USB 2.0
http://airspy.com/ is one of the products buil around it
« Reply #3 on: March 25, 2015, 02:28:53 am »
Thanks for the responses.  :)
Checked what you guys said, and wow does that STM32F303/LPC4370 look nice.
Unfortunately the design is cost-sensitive (plan on doing a 1-10k unit production run - sorry for not mentioning this) so it looks like the XMEGA (A4U) might be the best choice.
$1.67 on Digikey (vs about $1.80 for a STM32F302), easy to source and as mentioned good documentation/IDE/sample code.
Does that sound about right to you guys, or are there much better options out there?
