Author Topic: anybody using Asus Xtion as cheap LiDAR ?  (Read 5584 times)
Offline legacyTopic starter
« on: October 16, 2014, 11:02:39 pm »
hi guys
it could be fun, and OpenNI is supporting Xtion.
So, in case, any example of real usage ?
Offline Rasz
    • My random blog.
Re: anybody using Asus Xtion as cheap LiDAR ?
« Reply #1 on: October 17, 2014, 05:59:39 pm »
internally its pretty much 1:1 same thing as kinect, and you can get used kinect at <$50, so why would you want to pay ~$200 for asus?
btw they both have range limitations
Offline Alexei.Polkhanov
« Reply #2 on: October 17, 2014, 06:18:09 pm »
Hmm, BOSCH range finder/distance meter for $70 new will probably do job much better than any of these if you only care about LIDAR functionality not 3D.
« Reply #3 on: October 17, 2014, 06:55:46 pm »
because Xtion
1) is smaller
2) consumes less power
3) does not require power supply (except USB)
contro analysis
1) lower drivers quality: that it not a problem if used as "LiDAR"
2) does not work with some USB controllers (especially USB 3.0): it may be a problem with some USB-hub or linux embedded boards, so you have to check it out
3) no motor, it allows only manual positioning: not a problem, in my application the unit needs to be mounted into a fixed holder
« Last Edit: November 03, 2014, 03:02:54 am by legacy »
« Reply #4 on: October 17, 2014, 06:56:42 pm »
which one ? tell me more :D
« Reply #5 on: October 17, 2014, 07:50:55 pm »
p.s.
guys, i am looking for a LiDAR for robotics application, i am afraid that the BOSCH range finder is useless for my application.
something like that  :D
« Last Edit: October 17, 2014, 07:53:21 pm by legacy »
« Reply #6 on: October 31, 2014, 10:36:23 pm »
anybody using Xtion for robotics stuff  :-+ ?
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #7 on: November 01, 2014, 12:39:56 am »
What sort of distance do you need?
Have you looked at the Sharp GP2Y series of optical distance sensors?  They have some out to a few meters, IIRC.  I had an FAE bring some samples by a few months back along with a project he was working on (gesture control using those sensors to detect hand motions).  It worked pretty well and the parts are commonly available - and frequently used in robotics applications.
It's not always the most popular person who gets the job done.
« Reply #8 on: November 01, 2014, 01:36:28 am »
have you read the link ? i need a lidar for SLAM purposes, the Sharp GP2Y is not good for that  :D
Online NiHaoMike
    • Facebook Page
« Reply #9 on: November 03, 2014, 01:14:26 am »
The original Kinect can be hacked to be completely USB powered. Maybe the new Kinect can be hacked in a similar manner.
https://www.eevblog.com/forum/reviews/kinect-teardown/
« Reply #10 on: November 03, 2014, 03:09:29 am »
yep, nice to know, thank you :D
i like the Xtion also because it can be used in "lidar emulation", you only need a rotating base
