Yes, we use them here. What would you like to know about them?
I'm curious about the ease of use / setup, how well they are supported, learning curve..... have you used the EtherCAT functionality too?
I'm thinking of getting ahold of one for a motion control project.
I have been playing with the XMC4300 eval board, I got the Ethercat example running with not much trouble. I was pleasantly surprised with the DAVE environment and documentation.
The onboard Ethercat seems to be a unique feature in this type of MCU, which is what interested me.
Indeed, the actual chip is lower cost then the EtherCAT SoC from Beckoff.
Is the EtherCAT soley Slave or can it even master?
I've ordered a 4300 demo like yourself.
I believe it is slave only, but I wouldn't swear to that.
It would be nice if it could run as a master, that is something I want to look at. But maybe you can use an ethernet port as a master, with a suitable stack. I've only just started looking into EtherCAT.
That sounds about right. EtherCAT is a really great performance protocol. I'm quite intrigued with this chip, the price makes EtherCAT possibly as inviting as CANOpen...
Know any good pointers for getting familier with the Infineon XMC series?
