Author Topic: Anyone work with SHARC processors ?  (Read 29907 times)
Offline diyaudioTopic starter
« on: February 25, 2014, 08:55:18 am »
Hi
I'm looking at doing DSP development later this year, vie been looking into the SHARC processor platform however, the development boards and hardware tools are really really expensive 600 USD (I cannot afford it, it cost as much as a new Rigol scope  if not more) can anyone recommend or advise  an alternative development board or advise an alternative platform.
Cheaper platform mini SHARC running a ADSP21369. 185 USD (without shipping)
Alternative platform but limited the DAC is limited to 4 outputs. 195 USD (without shipping)
ADAU1442, ADAU1445, and ADAU1446 SigmaDSP Products.  600 US (without shipping)
« Last Edit: February 25, 2014, 09:04:15 am by diyaudio »
Offline Hideki
  • Country: no
Re: Anyone work with SHARC processors ?
« Reply #1 on: February 25, 2014, 09:49:04 am »
SigmaDSP is not SHARC. It's set up with a (slightly buggy) graphical drag and drop environment and you can't write programs in C for it.
While $185 may be a decent price for the devboard, don't forget that the compiler costs $3500 and the cheapest JTAG emulator is $1200.
« Reply #2 on: February 25, 2014, 10:03:57 am »
@Hideki
I actually meant the sigma as an alternative, I understand the SigmaDSP is not SHARC, Note there is SIGMA for SHARC as well.
http://www.analog.com/en/dsp-software/sh_sigst_00/sw.html
If I skip the cost of Visual DSP++ and use the Sigma for sharc, I can then get by using the USBi cable used it to upload the firmware to the processor using this
http://www.analog.com/en/evaluation/bfext-usbi2ezb/eb.html
I understand the critical point is this,  I can only then use the custom made blocks within the sigma studio unable to design and develop custom DSP algorithms of my choice.
« Last Edit: February 25, 2014, 10:13:53 am by diyaudio »
Offline Hideki
  • Country: no
« Reply #3 on: February 25, 2014, 10:27:15 am »
Note that SIGMA for SHARC still needs the $1200 emulator.
I guess it depends on how much you want it to do. Maybe the ADAU chips are enough for you.
At the low end, an ARM Cortex M4F can probably do more processing than a SigmaDSP - GCC is free, ARM JTAG is usually cheap (or already on the devboards), but finding suitable devboards for audio may be hard. STM32F4DISCOVERY at ~$17 plus an external I2S audio codec board perhaps.  A10-OLinuXino-LIME is only 30 euros for an 1 GHz Cortex A8, etc.
« Reply #4 on: February 25, 2014, 10:41:22 am »
Never worked with ARM boards I will look into the STM32F4DISCOVERY and a cheap JTAG.
Offline Hideki
  • Country: no
« Reply #5 on: February 25, 2014, 10:52:01 am »
You don't need it for that board since it has the ST-LINK/V2 built in.
« Reply #6 on: February 25, 2014, 11:06:27 am »
wow thanks they are very cheap, 20 USD, Im no expert at DSP processors I wonder how well the ARM M4 processor performs against the SHARC ADSP21369,  would like to hear what people as to say about that.
Offline dannyf
« Reply #7 on: February 25, 2014, 12:06:28 pm »
The CM4's dsp is no match for the sharc.
« Reply #8 on: February 25, 2014, 12:28:08 pm »
I had a gut feeling that is the case I found this seems like alternative hardware.
http://www.openadsp.com/proclass1.asp?class1id=7
Offline Hideki
  • Country: no
« Reply #9 on: February 25, 2014, 12:42:55 pm »
The M4F is a designed as a microcontroller, not a DSP, so it doesn't have all the neat (but sometimes hard-to-use) functionality that can make DSPs do things faster.
It's clocked at half the rate or slower (NXP has 204 MHz parts, ST 168 or 180 MHz versus 400 MHz SHARC). While the FPU is reasonably fast it can't do anything in parallel or load from multiple memory buses. The fixed point instructions are however not that bad. It can beat SigmaDSP but not SHARC.
For a hobbyist, the total price including compiler and other development hardware usually means using a DSP is out of the question, even if they have more performance.
This PDF compares SHARC and Cortex M4F, A8 (and A9).
http://www.dspconcepts.com/sites/default/files/white-papers/2011%20AES%20-%20DSP%20vs%20Micro%20rev%202.pdf
Your "alternative" hardware looks like chinese clones of Analog Devices and I'm sure it comes with equally cloned (well, direcly copied) software as well.
« Reply #10 on: February 25, 2014, 12:51:09 pm »
@Hideki
Many thanks for the PDF will go through this later ! Not many chinese clones of Analog Devices available on ebay search yields rather shy results.
Offline Hideki
  • Country: no
« Reply #11 on: February 25, 2014, 01:03:21 pm »
I just noticed this new product that they say can "execute up to three times more audio processing algorithms than its predecessors".
http://www.analog.com/en/audiovideo-products/audio-signal-processors/adau1452/products/product.html
Maybe an alternative if a cheap devboard appears.
Offline legacy
« Reply #12 on: February 25, 2014, 01:06:35 pm »
blackfin is too tiny for you ?
« Reply #13 on: February 25, 2014, 01:26:51 pm »
uhmm not bad. 225 USD for the dev board.
http://www.digikey.com/product-detail/en/EVAL-ADAU1452MINIZ/EVAL-ADAU1452MINIZ-ND/4571726
http://www.bdti.com/InsideDSP/2014/02/05/ADI
« Last Edit: February 25, 2014, 01:38:45 pm by diyaudio »
« Reply #14 on: February 25, 2014, 01:27:35 pm »
wayyyyy to expensive for me. :D
Offline legacy
« Reply #15 on: February 25, 2014, 06:16:37 pm »
it may cost less than $200, i payed $70 USD for a tiny BF532, brand new!
the problem is … you can't use VisualDSP++ with it, cause the cheapest jtag is $200 USD
i mean the cheapest jtag which VisualDSP++ v5 will accept and use
you could buy an open source jtag, e.g. ICE bear, which costs $50, but .. you have to forget to be able to use it with VisualDSP++
so you have to use opensource toolchain, that's not fun at all
anyway, if you want a very cheaper BF532 board i can suggest you a canadian seller
« Reply #16 on: February 25, 2014, 06:23:35 pm »
Sure why not throw me the seller,im almost certain the  EVAL-ADAU1452MINIZ should be okay..
Why does the analog guys make things so hobby unfriendly .
Offline legacy
« Reply #17 on: February 25, 2014, 11:11:25 pm »
this board is made by soc-robotics and it is sometimes sold on ebay at cheaper price (i bought 2 of units at $70 each), unfortunately it has no jtag included and it is using an AVR644 to load the blacken's binary code through the serial port into ram in order to burn the spi flash which is shared by blackfin and AVR644: it's done sector by sector, and it's a bit slow, but cheap.
« Last Edit: February 26, 2014, 01:15:57 am by legacy »
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #18 on: February 26, 2014, 12:39:29 am »
With regard to microcontrollers, only, right?  Everything else seems to have liberal sample policies and the ICs themselves are as easy to work with as anyone else's.  They have a lot of interesting parts.  But yeah, they make entry into their microcontrollers nearly impossible for a hobbyist, which is 100% the opposite of Atmel, Microchip, TI, ST, Silicon Labs, Zilog, Freescale, and Xilinx and Altera if you are counting FPGAs.  Everyone else has a cheap programmer and free (sometimes size limited or optimization limited) software at this point.
Have You Been Triggered Today?
« Reply #19 on: February 26, 2014, 02:48:50 pm »
Curiosity..
Can anyone provide further input, how will an FPGA  match against the SHARC ?
I came across the video.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #20 on: February 26, 2014, 03:44:07 pm »
Not sure if you are still looking for alternatives, but did you look at the floating point C6748 DSP from TI? It has much cheaper boards and free SW (here and here). Also, the IDE (Code Composer Studio) is free depending on the emulator you choose.
« Last Edit: February 26, 2014, 04:30:22 pm by rsjsouza »
Offline Hideki
  • Country: no
« Reply #21 on: February 26, 2014, 03:51:53 pm »
An FPGA makes sense when you want to duplicate the same type of processing N times, like you do in a mixer, but writing HDL instead of C code is very very different.
RME uses FPGA in their products.
Offline paf
« Reply #22 on: February 26, 2014, 08:53:38 pm »
No, No, No.
On a an FPGA, you can do what type of hardware blocks you need, and you can to different types of blocks with different sizes if you want.  If  you need  32 counters with sizes from 32 to 64 bits (all different) you can.
You need  20 FIFOs all with different widths, and with different sizes, you can do it.
Offline Hideki
  • Country: no
« Reply #23 on: February 26, 2014, 11:14:34 pm »
Yes, yes, yes. I'm talking about doing DSP-like processing - not counters and FIFOs. My guess would be that the FPGA does indeed handle lots of channels in parallel and large mixing matrixes instead of implementing completely custom circuitry per channel. That appears to be the RME way as well.
DiGiCo has three TigerSHARC DSPs on the board they display in their video, so there is absolutely some separation between what does what.
It's easier to run different code on the DSPs than to reconfigure the FPGA every time you want a different effect.
Offline SArepairman
  • wannabee bit hunter
« Reply #24 on: March 02, 2014, 11:30:44 pm »
before yoou make your decision check the internet for cracked programs. I got pretty upset at the numbers that came up in this thread.
if you are a hobbyist there is nothing wrong with cracking a 10,000$ program aimed at a company that has employees and shit being paid ten times that per year.
its senseless to use the "free" tools which are often buggy crap (like I switched from pirate Eagle cad to pirate altium  :phew:). If I continued to use eaglecad I would probably be dead by now.
its not like you are mugging people at the bus stop  :-+ and the company you are "stealing" it from does not give 0.00001% of a shit about you.
spend your money on nice test equipment and components instead. stuff that would actually hurt people to steal.
this specifically made me upset:
the fuck should I have to use some ghetto technology because of a software license  |O :palm: :scared: :blah: :wtf: :rant: :box: >:(
people need to get on cracking this shit ASAP
if you sell the chip for 50$ and you expect me to pay 5g for the software you are smoking crack
« Last Edit: March 02, 2014, 11:42:05 pm by SArepairman »
