I think that the 84MHz denotes the speed at witch the bus is able to allow communication between the CPU and the peripherals, not the actual speed of the peripherals attacched to it. You can also see from Cube that you have a x2 block before the clock is fed to the timers of such bus, so apparently timers are clocked separately from the rest of the peripherals
