Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
Reading the Code on a Microprocessor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Reading the Code on a Microprocessor (Read 2813 times)
wayneee
Newbie
on:
June 01, 2013, 09:05:12 pm »
Is it possible to read the code in a microprocessor once it has been placed on a circuit board?
Logged
PeterG
Frequent Contributor
Country:
Re: Reading the Code on a Microprocessor
Reply #1 on:
June 01, 2013, 09:14:44 pm »
I am not sure about Microprocessors but generally you can with Microcontrollers provided the chip is not code locked or otp.
Logged
Testing one two three...
Dave
Super Contributor
Country:
I like to measure things.
Reply #2 on:
June 01, 2013, 10:31:32 pm »
Yes, if the code is not read protected, you should be able to extract a hex file from the microcontroller. Then use a decompiler to convert that hex file back into human-friendly assembly code.
Logged
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
ninn
Newbie
Country:
Reply #3 on:
June 06, 2013, 02:37:16 pm »
I want to see that "human friendly" asm
Logged
nuhamind2
Regular Contributor
Country:
Reply #4 on:
June 06, 2013, 02:56:08 pm »
Quote from: ninn on June 06, 2013, 02:37:16 pm
Aren't people in the past talk assembly.
Logged
free_electron
Super Contributor
Country:
Reply #5 on:
June 06, 2013, 03:56:15 pm »
Sourcer always did a pretty good job ...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
