MISTERY SOLVED: it is a bug in the ESP8266 dtostrf() function implementation -> "core_esp8266_noniso.c".
It was affecting ESP8266 code only. Confirmed and fixed with the guys from Arduino Forum.
Correct dtostrf() function code below:
char * dtostrf(double number, signed char width, unsigned char prec, char *s) {
if(isnan(number)) {
strcpy(s, "nan");
return s;
if(isinf(number)) {
strcpy(s, "inf");
return s;
if(number > 4294967040.0 || number < -4294967040.0) {
strcpy(s, "ovf");
return s;
char* out = s;
// Handle negative numbers
if(number < 0.0) {
*out = '-';
++out;
number = -number;
// Round correctly so that print(1.999, 2) prints as "2.00"
double rounding = 0.5;
for(uint8_t i = 0; i < prec; ++i)
rounding /= 10.0;
number += rounding;
// Extract the integer part of the number and print it
unsigned long int_part = (unsigned long) number;
double remainder = number - (double) int_part;
out += sprintf(out, "%d", int_part);
// Print the decimal point, but only if there are digits beyond
if(prec > 0) {
*out = '.';
++out;
while(prec-- > 0) {
remainder *= 10.0;
if((int)remainder == 0){
*out = '0';
++out;
sprintf(out, "%d", (int) remainder);
return s;
