Author Topic: Arduino Nano Modbus energy meter SDM230  (Read 2700 times)
Offline PSR B1257Topic starter
« on: January 25, 2022, 06:26:38 pm »
Hy guys, one's again a Arduino problem.
I am trying to read the Modbus-interface of an SDM230 energy meter, using these codes: https://github.com/peninquen/Modbus-Energy-Monitor-Arduino/tree/master/Old_versions/Modbus-Energy-Monitor-Arduino
The energy meter is connected via a RS458-TTL-converter.
The only change I made so far, was to edit one line in the Modbus-Energy-Monitor-Arduino.ino file
#define MB_SERIAL_PORT &Serial1
to
since Arduino Nano has just one serial port.
With that, the whole mess at least compiles.
But I get no activity on the TX/RX pins, and therefore only gibberish (as far as the data goes) on the serial port , the header is fine.
I compared the data-addresses from the SDM120 to my SDM230, and they are the same.
Could it be, that this code is not compatible with Arduino Nano?
Best regards,
Mathias
In theory, there is no difference between theory and practice. But, in practice, there is.
Offline fchk
Re: Arduino Nano Modbus energy meter SDM230
« Reply #1 on: January 25, 2022, 07:45:27 pm »
Did you check the TX, RX, and DE (Transmitter Enable) signal with a logic analyzer? If yes, please post a screendump of a transaction.
If you don't have a logic analyzer: there are plenty of these cheap 24 Mhz/8 channel Saleae clones on Amazon and ebay for about 10€. Well invested money!
fchk
« Reply #2 on: January 25, 2022, 08:15:43 pm »
No, but with my DSO  ;)
The only activity is on the 'TxEnablePin'.1391927-0
Offline ledtester
« Reply #3 on: January 26, 2022, 05:13:21 am »
Have a look at these lines in the Arduino library:
#define MODBUS_SERIAL_OUTPUT  //Verbose MODBUS messages and timing
#ifdef MODBUS_SERIAL_OUTPUT
#define MODBUS_SERIAL_BEGIN(...) Serial.begin(__VA_ARGS__)
#define MODBUS_SERIAL_PRINT(...) Serial.print(__VA_ARGS__)
#define MODBUS_SERIAL_PRINTLN(...) Serial.println(__VA_ARGS__)
#else
#endif
The library is printing debugging messages with the Serial object. This is verified by the screenshot of your output -- the "MASTER:" stuff is part of a debug message. The garbage following "MASTER:" is the actual MODBUS packet.
Try undefining MODBUS_SERIAL_OUTPUT and see what happens.
« Reply #4 on: January 26, 2022, 09:21:21 am »
Unfortunately nothing. I have changed these lines to comment and get the same on the serial monitor  ???
Offline ledtester
« Reply #5 on: January 26, 2022, 12:22:31 pm »
What exact lines did you change?
A sure-fire way to disable the debugging output is to replace these lines in the library file:
#else
#endif
with:
i.e. delete a bunch of lines
« Reply #6 on: January 26, 2022, 12:53:12 pm »
All lines you selected above.
with:
Still no change.
But now I have at least some activity on TX pin.
Offline ledtester
« Reply #7 on: January 26, 2022, 02:11:53 pm »
What does your serial monitor look like?
« Reply #8 on: January 26, 2022, 04:13:17 pm »
Look's still kinda crazy...
Offline ledtester
« Reply #9 on: January 26, 2022, 06:15:03 pm »
Is it one of these converters? How are the DE and RE pins wired?
1392695-0
« Reply #10 on: January 27, 2022, 06:31:39 am »
That's the one.
DE and RE are shorted and connected to the TxEnablePin.
The unit is working. I have measured the RS458 port both with the energy meter connected and disconnected (to make sure the interface of the energy meter does not cause any funny business).
Later this day, I will try a different code and ditch this one - can't be worse.
Offline ledtester
« Reply #11 on: January 27, 2022, 07:51:53 am »
You might look at this one:
https://github.com/smarmengol/Modbus-Master-Slave-for-Arduino
It has an example which uses a software serial interface to the 485 module -- then you won't see the MODBUS packets on your terminal.
Offline fchk
« Reply #12 on: January 27, 2022, 07:59:14 am »
That's the one.
This board has a serious problem. You need three Terminals: RS485 A, RS485 B, and Ground. The Ground terminal is missing. You MUST connect Ground between the meter and the RS485 interface. Otherwise the common mode range might be exceeded.
For the future, just avoid this board and look for this one:
fchk
Offline ledtester
« Reply #13 on: January 27, 2022, 08:24:17 am »
@fchk, the image didn't come through.
« Reply #14 on: January 27, 2022, 08:36:56 am »
Is already connected  :-+
Yeah...well...did I mention, that I have basically no idea what I'm doing? Copying some code, try it it and hope for the best is my premise  :-DD
I can't even figure out, where to define the 'addresses of interest' (measurement values of the energy meter).
« Reply #15 on: January 27, 2022, 04:37:12 pm »
Found a much simpler (and promising) code: https://web-relays.com/en/blog/arduino-code-read-voltage-from-eastron-sdm230-modbus-smart-energy-meter-with-modbus-protocol/
But of course, it doesn't work on the Arduino Nano. It only generates one single data-package on the TX pin and does not run though the main loop...
It seems it's much depended of the "special Arduino board".
Offline ledtester
« Reply #16 on: January 27, 2022, 05:27:15 pm »
Did you change RS485_control to your TxEnablePin?
What do you mean it "doesn't run through the main loop"?
This is a pretty good explanation of how MODBUS messages are created:
https://ipc2u.com/articles/knowledge-base/modbus-rtu-made-simple-with-detailed-descriptions-and-examples/
« Reply #17 on: January 27, 2022, 06:02:29 pm »
Yes.
The whole code is only executed one time.
« Reply #18 on: February 06, 2022, 06:19:41 pm »
The original code was just fine. Turns out, the RS485-converter was dodgy for crying out loud  :rant: A possibility which I should have been checking a bit earlier, duh  :palm:
The following users thanked this post: ledtester
