On the Arduino side it's pretty easy, just use the 5V from the Arduino itself.
On the cp2102 side, assuming you're powering it off USB power, then the cp2102 has an internal voltage regulator capable of 100mA. Given the cp2102 needs about 26mA of power, that leaves you with around 70mA at 3V.
Or alternatively it looks like the IO pins are 5V tolerant, so you could power it off the USB supply directly. But double check that on the datasheet before you go ahead, I've only had a quick look.
https://www.silabs.com/Support%20Documents/TechnicalDocs/cp2102.pdf
