Author Topic: Good Wifi chip?  (Read 13207 times)
Offline richardmanTopic starter
Re: Good Wifi chip?
« Reply #25 on: October 15, 2015, 01:43:48 am »
Anyone with experience with the Broadcom BCM43362 Wi-Fi chip?
It's being by "Photon"
// richard http://imagecraft.com/
JumpStart C++ for Cortex (compiler/IDE/debugger): the fastest easiest way to get productive on Cortex-M.
Smart.IO: phone App for embedded systems with no app or wireless coding
Offline boriz
Re: Good Wifi chip?
« Reply #26 on: October 26, 2015, 03:38:11 pm »
I am currently using the esp8266, programming it in the native api.
Made it into an irc-bot so you can control it via irc instead of bloated http.
It is pretty stable, but can hang up if you produce serial debug data faster than the
buffer can handle, so just keep the debugging out on the uart to levels so it won't overflow,
the buffer, at which point the device will reboot :(.
There are also issues with the ssl, it works if your device act as a https server,
then you just supply it with its private,public key etc.
But if you use it for https or use it for encrypted connections to any other protocol as
a client, you are most likely out of luck, as it doesn't support newer certificates that most
endpoints use these days.
There is a good amount of ram on the beast, that part is a joy to work with and much
easier when you arent limited to 750 bytes as i am used to on lower end pic's.
The best bang for the buck that i have found so far. Most of the major "houses" are making
full tcp stack wifi chips, but the price is at the $30 price range pr unit and thats before
you have added the glue components and pcb.
Offline don.key
Re: Good Wifi chip?
« Reply #27 on: October 26, 2015, 09:46:36 pm »
A guess a novice question:
Am I correct to assume that all those modules seem to handle OSI layers 1-5, with TCP/IP stacks etc?
But what is if I do not want that, I want my main MCU's RTOS and TCP/IP stack to handle everything above layer 2. Can this be (efficiently) be done with chips such as CC3100 or ESP8266?
Thanks
Offline don.key
Re: Good Wifi chip?
« Reply #28 on: October 27, 2015, 09:01:49 am »
So CC3100 seems to be the only real option in that case.
Bummer, not that I have something against CC3100 but it is definitively a overkill for what I am looking for and there seems to be no other option.
