Author Topic: Arduino ProMini car project ws2812b  (Read 805 times)
Offline jipaionutcatalinTopic starter
« on: April 24, 2020, 08:59:50 am »
Hi all
I have this project in mind, rear signal light and brake to a ws2812b 12 led strip, 6 for a left signal turn yellow, 6 for a right turn yellow and 12 red led when brake. Because it is at the rear I need to take the 'signal' for my mini pro Arduino i/o pins from the light itself which will be 12 v. What I need to use to convert the ground and positive 12 v to a signal input for the pro mini?. Thanks in advance.
Offline tmadness
Re: Arduino ProMini car project ws2812b
« Reply #1 on: April 24, 2020, 07:28:35 pm »
A simple voltage divider should be enough, but automotive 12 v tends to be dirty with spikes >> 12 V so you can feed the reduced voltage through a optocoupler.  You could add a few clamping diodes to further mitigate those nasty spikes.
something like this should work, https://www.vishay.com/docs/84433/voma617a.pdf . But there are probably dozens of alternatives.
« Reply #2 on: April 25, 2020, 09:58:50 am »
Thx for that.
Offline mikerj
« Reply #3 on: April 25, 2020, 05:04:58 pm »
What are you going to do when braking and indicating?  Turn signal spacing on a strip of 12 LEDs will not be legal in the UK.
Offline jackthomson43
« Reply #4 on: May 01, 2020, 12:46:22 pm »
You can use simple relay boards or FETs i.e. 75N75. It will be placed in between Arduino Pro Mini & ws2812b and using FET you can easily control 12V LEDs with 5V logic. Read it out. How to use FETs as a switch.
Btw in your case simple NPN transistor i.e. BC547 will also work as ws2812b doesn't need much amperes.
« Last Edit: March 04, 2021, 05:45:10 am by jackthomson43 »
