I'm stumped; hoping someone can or offer a path to success.
Back in 2019 I nearly finished a microcontroller design using the ATmega32U2. I had written the code using the Arduino IDE and had a rather rich instruction set communicated over the Serial interface. I ran into some "life getting in the way" things along with some "keep it simple, stupid" ideas which forced me to take the design back to the drawing board in an effort to reduce component count and thereby cost.
I created Fab D and got the PCB design back from OSHpark and I re-factored the code I already had and attempted to use it. Welp, sometime between 2019 and now I rebuilt my computer and had to re-install windows 10 clean. I still have the code; but now I can't get the Arduino code to work. Specifically the Serial calls work in that I'm able to send data from the device back to the serial port.
But I'm not able to receive anything from the computer into the device.
I have the HEX files from the original code; and they do indeed receive/transmit. But newly compiled code doesn't work to receive.
I've even went so far as to install one of the "SerialEvent" demos which also doesn't work.
I'm convinced that something isn't setup correctly on the clean install of windows; but can't figure out where the problem is if even the simple demo doesn't work.
Thoughts?
