Author Topic: Arduino uno Bit overflow... need help solving this  (Read 2704 times)
MikeJuszkie
  • Guest
« on: July 31, 2012, 11:33:14 pm »
I am currently working on my own power supply that is controlled by an arduino. I am having issues with bit overflow, for current 5 volts is going to represent 1 Amp. The 5 volts in pwm is represented with a value of 255 but I would like to convert this value to 1000 mA. Everything I have tried has failed and I know the issue is that there is a loss of data when doing the math due to bit overflow. Can somebody please help.
here is the section of code that I am dealing with that I am having the problems with.
        int Vout = analogRead(pinVread);
        int Cout = analogRead(pinCread);
        float Vset = (voltage / 25.5);
        float Cset = current * (1000 / 255);
        float vout = (Vout / 102.3);
        float cout = Cout * (1000/ 1023);
The variables (voltage) and (current) are used much earlier in the program as the PWM outputs.
whenever it goes to display the value, instead of displaying a max of 1000 mA it shows a max of 765. and if you do the math, you will see that am losing everything after the decimal place for the "(1000/255)"
In the case of the second half those values are read from the analog inputs which are 10 bit not 8 bit. That one will not even show that value at all.
MikeJuszkie
  • Guest
Re: Arduino uno Bit overflow... need help solving this
« Reply #1 on: July 31, 2012, 11:53:03 pm »
I actually just fixed the issue. I just needed to add a  .00 to the end of the numbers I was using.
MikeJuszkie
  • Guest
« Reply #2 on: July 31, 2012, 11:53:40 pm »
        float Cset = current * (1000.00 / 255.00);
        float cout = Cout * (1000.00/ 1023.00);
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #3 on: July 31, 2012, 11:55:02 pm »
Is it not because you're using integer division? Changing it to 1000.0 will force it to using floating point?
Or am I not reading the question right?
Chet
Paid Electron Wrestler
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #4 on: July 31, 2012, 11:56:10 pm »
Damn you tapatalk and your non notification of replies :p
Chet
Offline darrylp
« Reply #5 on: August 01, 2012, 12:20:52 am »
the MAP function will scale values from one range to another.
its documented on the arduino.cc web page.
