Author Topic: Arduino USB Host or no USB Host?  (Read 4453 times)
Offline zdelarosa00Topic starter
  • Country: mx
  • Manipulate your machine, you're a Technomancer...
« on: May 21, 2015, 10:59:31 pm »
Hi everyone, my third question on the forum here, now is... I know Arduino has a usb controller chip on it to conenct it to the compter and to use the IDE and program it, now my question is.. Can I plug a USB device to an Arduino without a USB-Host shield?, I've seen cases like this video: https://www.youtube.com/watch?v=1diFaa5OsFg, where you just use the USB pair of pins on the device and TX & RX on he Arduino to make the couple work, recieve and send information, but I've asked(?) before and apparently even with a simple usb mouse or small keyboard you need a USB host device or a "USB-UART / USB-RS232" (or are the shields actually the same rs232?) translator thing in order to make the couple work as the arduino being the host and the usb device to be used. Am I completely lost here..?. Anyway, thank you and I appreciate any help, good vibrations to everyone from Mexico.  :-+
USB Host Shield: http://www.dx.com/p/usb-host-shield-2-0-board-166217#.VV5jMai3vKg
Space landfill waste consultants say: "If you think you can or if you think you can't you're right" - Always on my way to be a better electronic wizard
Online ataradov
    • Personal site
Re: Arduino USB Host or no USB Host?
« Reply #1 on: May 21, 2015, 11:10:09 pm »
No,  standard Arduino can't do host on its own. What makes you think that it is a USB host on that video? They are connecting a sensor with I2C/SPI/UART/whatever interface and use Arduino USB port for serial communication.
Arduino Zero has USB Host controller, but it is mostly vaporware right now.
Alex
  • Country: mx
« Reply #2 on: May 22, 2015, 03:48:25 am »
So if I connect a keyboard or mouse to TX &  RX should I get results on the serial monitor?
Online ataradov
    • Personal site
« Reply #3 on: May 22, 2015, 04:56:47 am »
No, you won't. There is no RX and TX in USB. You can connect PS/2 keyboard, but that's probably not what you want.
Also, you don't just get results on the serial port, you need to write firmware to do so.
Alex
Offline pickle9000
« Reply #4 on: May 22, 2015, 05:06:01 am »
Offline timb
    • timb.us
« Reply #5 on: May 22, 2015, 12:02:10 pm »
Arduino Mega ADK can do USB Host.
Sent from my Tablet
  • Country: mx
« Reply #6 on: May 23, 2015, 04:17:48 pm »
And can I program an Uno to work as a USB to Serial converter?, or as a USB Host? .... And that means that device in the video is not USB??, it looks like it is and all the similar fingerprint readers that i've seen are USB  :(
« Last Edit: May 23, 2015, 04:26:29 pm by zdelarosa00 »
Offline neslekkim
  • Country: no
« Reply #7 on: May 23, 2015, 04:39:13 pm »
It's specified on the adafruit productpage, TTL Serial..
  • Country: mx
Offline jeristair
« Reply #9 on: May 24, 2015, 11:32:50 pm »
If you're talking about a USB Keyboard here, then yes, it would work, most wired USB Keyboard's can default back to the PS/2 interface using the USB connector.
