Dear Sir
I am stuck in the sending part. i use SSCOM32 window monitor to transmit. the issue is as follow when i enter zero the code should know that it's in the transmitting phase. else it's receiving. what i noticed is that when i connect to pin 0,1,2,3 and 4 the transmitting led stays on without doing any thing, also when i transmit the led send something very different of what i have entered "’928 þÊ928 ʹʒÂ" i don't know what is that. so can u please help
while(blueToothSerial.available() && blueToothSerial.read() == '0') {
blueToothSerial.println("Transmitting");
while (blueToothSerial.available() == 0) {
delay(50);
while (blueToothSerial.available() > 0 ) {
readString += (char)blueToothSerial.read();
value = readString.toInt();
for (int i = 0; i < 3; i++) {
irsend.sendNEC(value,32);
delay(40);
blueToothSerial.println(value,HEX);
readString = "";
Hello!
I am stuck on a project I'm working on. The idea is to have an android tablet control an arduino over bluetooth and have the arduino in turn control an IR led. The idea is to make an universal remote that you can point your original IR remote to and record codes, then have the tablet trigger these without having to point the tablet at the device being controlled (one of the drawbacks of using an internal IR led on the tablet/phone IMO).
I have:
Grove BlueTooth module
IR reciever
IR led
and an arduino uno.
The example code provided with the bluetooth module works fine and i can pair with it.
I also tested out the IRremote library with a test program called IRrecord
This also works a treat and i can record codes from my tv remote and play them back through the IR led and control the tv.
The problem is in when i try to stitch these two examples together I cant get the IR part to work. And if i comment out the bluetooth code it works. This leaves me to believe that they both use the same interrupt and/or timers. I cant find any refrense to the timers used in the SoftwareSerial library used by the bluetooth.
Anyone have any ideas on where to start digging? Seems some other people have had the same issues, but i cant find any answers.
Ive started a my first Repo for this project.
My first attempt to stitch these two together:
* IRrecord: record and play back IR signals as a minimal
* An IR detector/demodulator must be connected to the input RECV_PIN.
* An IR LED must be connected to the output PWM pin 3.
* A button must be connected to the input BUTTON_PIN; this is the
* send button.
* A visible LED can be connected to STATUS_PIN to provide status.
* The logic is:
* If the button is pressed, send the IR code.
* If an IR code is received, record it.
* Version 0.11 September, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 6 //BT RX
#define TxD 7 //BT TX
int RECV_PIN = 11; //IR in
int BUTTON_PIN = 12; //Button to send IR
int STATUS_PIN = 13; //Indicate IR activity
//IR TX is hardcoded to pin 3 on Arduino Uno. Doesnt nativly work with Arduino Mega
IRrecv irrecv(RECV_PIN);
IRsend irsend;
decode_results results;
SoftwareSerial blueToothSerial(RxD,TxD);
void setup()
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
pinMode(BUTTON_PIN, INPUT);
pinMode(STATUS_PIN, OUTPUT);
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
setupBlueToothConnection();
// Storage for the recorded code
int codeType = -1; // The type of code
unsigned long codeValue; // The code value if not raw
unsigned int rawCodes[RAWBUF]; // The durations if raw
int codeLen; // The length of the code
int toggle = 0; // The RC5/6 toggle state
// Stores the code for later playback
// Most of this code is just logging
void storeCode(decode_results *results) {
codeType = results->decode_type;
int count = results->rawlen;
if (codeType == UNKNOWN) {
Serial.println("Received unknown code, saving as raw");
codeLen = results->rawlen - 1;
// To store raw codes:
// Drop first value (gap)
// Convert from ticks to microseconds
// Tweak marks shorter, and spaces longer to cancel out IR receiver distortion
for (int i = 1; i <= codeLen; i++) {
if (i % 2) {
// Mark
rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK - MARK_EXCESS;
Serial.print(" m");
else {
// Space
rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK + MARK_EXCESS;
Serial.print(" s");
Serial.print(rawCodes[i - 1], DEC);
Serial.println("");
else {
if (codeType == NEC) {
Serial.print("Received NEC: ");
if (results->value == REPEAT) {
// Don't record a NEC repeat value as that's useless.
Serial.println("repeat; ignoring.");
return;
else if (codeType == SONY) {
Serial.print("Received SONY: ");
else if (codeType == RC5) {
Serial.print("Received RC5: ");
else if (codeType == RC6) {
Serial.print("Received RC6: ");
else {
Serial.print("Unexpected codeType ");
Serial.print(codeType, DEC);
Serial.println("");
Serial.println(results->value, HEX);
codeValue = results->value;
codeLen = results->bits;
void sendCode(int repeat) {
if (repeat) {
irsend.sendNEC(REPEAT, codeLen);
Serial.println("Sent NEC repeat");
else {
irsend.sendNEC(codeValue, codeLen);
Serial.print("Sent NEC ");
Serial.println(codeValue, HEX);
irsend.sendSony(codeValue, codeLen);
Serial.print("Sent Sony ");
else if (codeType == RC5 || codeType == RC6) {
if (!repeat) {
// Flip the toggle bit for a new button press
toggle = 1 - toggle;
// Put the toggle bit into the code to send
codeValue = codeValue & ~(1 << (codeLen - 1));
codeValue = codeValue | (toggle << (codeLen - 1));
Serial.print("Sent RC5 ");
irsend.sendRC5(codeValue, codeLen);
else {
irsend.sendRC6(codeValue, codeLen);
Serial.print("Sent RC6 ");
else if (codeType == UNKNOWN /* i.e. raw */) {
// Assume 38 KHz
irsend.sendRaw(rawCodes, codeLen, 38);
Serial.println("Sent raw");
int lastButtonState;
void loop() {
// If button pressed, send the code.
int buttonState = digitalRead(BUTTON_PIN);
if (lastButtonState == HIGH && buttonState == LOW) {
Serial.println("Released");
irrecv.enableIRIn(); // Re-enable receiver
if (buttonState) {
Serial.println("Pressed, sending");
digitalWrite(STATUS_PIN, HIGH);
sendCode(lastButtonState == buttonState);
digitalWrite(STATUS_PIN, LOW);
delay(50); // Wait a bit between retransmissions
else if (irrecv.decode(&results)) {
storeCode(&results);
irrecv.resume(); // resume receiver
lastButtonState = buttonState;
char recvChar;
while(1){
if(blueToothSerial.available()){//check if there's any data sent from the remote bluetooth shield
recvChar = blueToothSerial.read();
Serial.print(recvChar);
if(Serial.available()){//check if there's any data sent from the local serial terminal, you can add the other applications here
recvChar = Serial.read();
blueToothSerial.print(recvChar);
void setupBlueToothConnection()
blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); //set the bluetooth name as "SeeedBTSlave"
blueToothSerial.print("\r\n+STPIN=0000\r\n");//Set SLAVE pincode"0000"
blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
delay(2000); // This delay is required.
blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
Serial.println("The slave bluetooth is inquirable!");
blueToothSerial.flush();
Thanks for your time.
Edit: Fixed links
