Author Topic: [Solved] ARM Cortex-M0 - How to load large literal?  (Read 2631 times)
Offline DavidAlfaTopic starter
« on: January 07, 2024, 06:15:04 pm »
I have a hardfault wrapper copying the registers before going to the real hardfault function (Made for CM0) which I got from here:
LDR     R1, =HardFault_Handler_cp
It always worked in all conditions, until I tried enabling flto optimization (Got additional 10KB flash in CM3), then I got;
"Error: invalid offset, value too big (0x00003B4C)".
I understand the literal is too large (Largest literal for LDR in CM0 is 1020), how could I split this instruction into several ones?
Like: Load first byte, load second byte, or whatever? My knowledge in ARM assembly is close to zero.
I checked the CM0 LDR instruction docs.
I tried searching how to make a const-struc expression, perhabs I could find a way to load it in steps, but found nothing.
STR     R2, [R0,#const-struc]  ; const-struc is an expression evaluating to a constant in the range 0-1020.
Also it seems strange to me that it works without flto, it's loading the literal for HardFault_Handler_cp address after all?
« Last Edit: January 07, 2024, 07:55:32 pm by DavidAlfa »
Online langwadt
The following users thanked this post: DavidAlfa
Re: ARM Cortex-M0 - How to load large literal?
« Reply #2 on: January 07, 2024, 07:21:29 pm »
Thanks. I understand it's due the "Literal pool" thing:
If the next literal pool is out of range, the assembler generates an error message.
In this case you must use the LTORG directive to place an additional literal pool in the code.
Place the LTORG directive after the failed LDR pseudo-instruction, and within ±4KB (ARM, 32-bit Thumb-2) or in the range 0 to +1KB (pre-Thumb-2 Thumb, 16-bit Thumb-2).
See LTORG for a detailed description.
Edit: It was ".LTORG", not "LTORG":
__attribute__((used)) __attribute__((naked)) void HardFault_Handler_(void){
  asm(
      "MOV     R1, LR                       \n"
      "LDR     R0, =HardFault_Handler_cp    \n"
      "MOV     LR, R0                       \n"
      "MOVS    R0, #4                       \n"     // Determine correct stack
      "TST     R0, R1                       \n"
      "MRS     R0, MSP                      \n"     // Read MSP (Main)
      "BEQ     .+6                          \n"     // BEQ 2, MRS R0,PSP 4
      "MRS     R0, PSP                      \n"     // Read PSP (Process)
      "MOV     R1, R4                       \n"     // Registers R4-R6, as parameters 2-4 of the function called
      "MOV     R2, R5                       \n"
      "MOV     R3, R6                       \n"     // sourcer32@gmail.com
      "BX      LR                           \n"
      ".LTORG                               \n"     // Place literal pool outside of code execution
« Last Edit: January 08, 2024, 01:46:01 am by DavidAlfa »
Offline abyrvalg
« Reply #3 on: January 07, 2024, 07:44:45 pm »
Your constant gets placed right where .ltorg is and in current form you are executing those 4 bytes as code (CPU doesn’t treat them as a part of LDR instruction and doesn’t skip them). Move it out of execution flow (i.e. behind bx lr).
« Reply #4 on: January 07, 2024, 07:46:17 pm »
Thanks!  :-+
As I say this is not my job nor my studies (At least for now), just DIY/ hobby, so lots to learn yet.
After more RTFM I found exactly what you said:
You must place literal pools where the processor does not attempt to execute them as instructions.
Place them after unconditional branch instructions, or after the return instruction at the end of a subroutine.
« Last Edit: January 07, 2024, 07:57:47 pm by DavidAlfa »
Offline Tation
  • Country: pt
« Reply #5 on: January 07, 2024, 11:05:11 pm »
It's "LTORG" in the armasm syntax, but ".ltorg" in the gas one. Obviously you are using the 2nd one. In armasm directives do not begin with a dot, whereas in gas all start with it. Not all armasm directives are ported to gas by just prepending a dot, though.
Re: [Solved] ARM Cortex-M0 - How to load large literal?
« Reply #6 on: January 07, 2024, 11:34:41 pm »
I have no idea what gas is, I don't do arm asm :)
Offline abyrvalg
« Reply #7 on: January 08, 2024, 12:47:08 am »
Your toolchain is GCC, so your asm is “gas” :) With Keil MDK you’d need the “armasm” syntax (ARMCC/ARMClang toolchains).
Looks like there is a typo in your code: the LDR in question has R1 destination, but the next instruction moves some uninitialized R0 to LR (where you jump finally).
« Reply #8 on: January 08, 2024, 01:49:31 am »
Damm, yeah it was R0, no idea how it became R1 during the process!
Offline Tation
  • Country: pt
« Reply #9 on: January 08, 2024, 10:46:55 am »
In Keil you can also select the asm syntax to use:
« Last Edit: January 08, 2024, 10:48:31 am by Tation »
Offline bson
« Reply #10 on: January 17, 2024, 08:21:19 pm »
No need to use R0, you can load directly to LR: LDR LR, =label
LR is just R14.
Note that if label refers to a function, the linker will automatically set the low bit in the literal if you compile with -mthumb.
« Reply #11 on: January 17, 2024, 08:31:43 pm »
Yeah it did normally work without adding the literal pool, but failed when enabling -flto optimization.
Of course, stm32 is compiled with -mthumb!
Don't know why, I just wanted to get it sorted and fly away!  ;)
BTW your suggestion didn't work. Maybe it would for CM3, but it seems CM0 can only perform LDR operations on R0-R7 registers.
Error: lo register required -- `ldr LR,=HardFault_Handler_cp'
Edit: Indeed: https://developer.arm.com/documentation/dui0497/a/the-cortex-m0-instruction-set/memory-access-instructions/ldr-and-str--immediate-offset
Rt and Rn must only specify R0-R7.
« Last Edit: January 17, 2024, 09:11:38 pm by DavidAlfa »
Offline brucehoult
« Reply #12 on: January 18, 2024, 12:34:01 am »
All Cortex-M support only Thumb mode.
You have to go back to ARM7TDMI (or ARM9, maybe there's something else newer pre -M) or up to an A-series to get non-Thumb mode.
Sure. Thumb1 / ARMv6-M support using r8-r15 only with ADD, CMP, MOV and BX. Plus the special (implied) operations that use SP, LR, PC for their special purpose.
Offline westfw
« Reply #13 on: January 18, 2024, 08:46:39 am »
Don't know why
-flto essentially causes the compiler to inline a lot of code that wouldn't normally be inlined, resulting in (for example) a very large main() function with all your nice modular function special-cased and inlined, with occasional calls to library functions that didn't come under the -flto umbrella.
So it's not surprising that a function would get too large to access a literal pool in its normal position "after" the function body.
« Reply #14 on: January 18, 2024, 10:50:37 am »
Still, why does it miss placing a literal pool? Shouldn't handle this automatically?
Online ejeffrey
« Reply #15 on: January 18, 2024, 08:16:02 pm »
As near as I can tell, and would love to be corrected by someone who actually knows, the compiler handles making sure the literal pools it needs are there, with or without LTO.  If the function grows too large for a single literal pool it will create more .  But if you write an assembly function and don't provide a literal pool it will happily use one of the ones provided by the compiler assuming it's in range. But if the pool you are squatting on moves it won't try to fix it because that was your responsibility.
