Author Topic: MicroXplorer 3.0 for STM32, now with config code generation  (Read 3302 times)
Offline KedasProbeTopic starter
« on: March 16, 2013, 11:31:48 am »
Anyone used this already?
I tried generating code and it generated 'nice' looking code.
Some editing required but you have a structure and less likely you forgot to set something or did it wrong.
Website:
http://www.st.com/web/catalog/tools/FM147/CL1794/SC961/SS1533/PF251717
« Last Edit: March 16, 2013, 11:43:29 am by KedasProbe »
Not everything that counts can be measured. Not everything that can be measured counts.
[W. Bruce Cameron]
Offline Harvs
Re: MicroXplorer 3.0 for STM32, now with config code generation
« Reply #1 on: March 18, 2013, 01:24:10 am »
I had a play around with this having seen your post.
From what I can see, it just generates the IO setup code (unless I'm missing something.)  Which to be honest, is the easiest bits of setting up the peripherals for these devices.
I guess it's of some use, but it needs to do a lot more to make it worth using.  Like you can select a peripheral (say USART2), it will plonk down the pins it likes the look of on the package, then to change it you still need to pull out the datasheet and find out what other pins could be used for that peripheral.  It should have a drop down listing all the alternate pins for each peripheral.
It seems like a fairly large tool that doesn't really do much.
