For a long time I have been considering whether I should make a RISC-V port of my Forth-based RTOS, zeptoforth, which is currently for ARM Cortex-M0+/M4/M7 and when I first saw the mention of the Pine64 Ox64 I thought "maybe I will do that sometime in the near future" - it is (will be, once you can buy it) price-competitive with the ARM Cortex-M0+ RP2040-based boards that I have been focusing on as of late and significantly more powerful. But when I saw the actual specs of the thing I immediately recoiled - three cores where each of the three cores runs a different RISC-V architecture, one of them 64-bit and two of them 32-bit?! Designing an RTOS to take advantage of such a design is insane! Were I to make a port, I would just use the 64-bit core and ignore the two 32-bit cores. This contrasts with the RP2040, which is a very suitable target for symmetric multiprocessing due to its very symmetric design. Also consider the case of the STM32H745 DISCOVERY, which I own one of - it has separate ARM Cortex-M4 and Cortex-M7 cores, which makes it less attractive of a target due to their asymmetry; were I to target it I would probably just target the Cortex-M7 core and largely ignore the Cortex-M4 core (even though the board's cost, and thus less demand for support, makes me unlikely to bother; my board is still in its packaging, for one). All of this taken into consideration, I would wish that manufacturers would just make symmetric designs and not bother with asymmetric designs which, while sounding attractive to the kind of people who are like "well, we can do high performance computing on the 64-bit core, and low-power operation on one of the 32-bit cores, all at the same time!", make targeting them with practical RTOS designs one major PITA.
