Author Topic: Is there a way to get access to unexposed pins of an ESP-32?  (Read 886 times)
Online RAPoTopic starter
I have an ESP32-cam board that is working fine.
I need access to the two DACs but they are not exposed to a pin.
Is there a way to get (reliable) access to these pins?
Offline ArdWar
  • Country: sc
Re: Is there a way to get access to unexposed pins of an ESP-32?
« Reply #1 on: July 04, 2023, 11:50:51 am »
The two DAC pins are used internally by the camera module, so unfortunately no easy way to reuse them.
« Reply #2 on: July 04, 2023, 04:47:28 pm »
Thanks,
That means going to use a separate ESP-32 and a separate OV6770.
