Author Topic: ATmega328P ADC help  (Read 3843 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
ATmega328P ADC help
« on: November 11, 2017, 12:46:02 pm »
I am trying to set up continuous conversion on ATmega328P ADC. However the ADC interrupt is not firing. What mistake am I making here?
void adc_init(void)
skip_sample = true;
sample_id = 0;
ADMUX = 0;
ADCSRA = _BV(ADEN) | _BV(ADATE) | _BV(ADIE) | _BV(ADPS1) | _BV(ADPS0);
ADCSRB = 0;
DIDR0 = _BV(ADC0D);
ADCSRA |= _BV(ADSC) | _BV(ADIF);
Offline MasterT
Re: ATmega328P ADC help
« Reply #1 on: November 11, 2017, 01:21:34 pm »
Have you missed to include interrupt subroutine?
Offline Siwastaja
« Reply #2 on: November 11, 2017, 02:14:31 pm »
Interrupts still globally turned off? I.e., have you forgotten sei()?
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: November 11, 2017, 02:28:18 pm »
Implies the system clock is only 1.6Mhz.
Should ADIF be ADIE.
  • Country: cn
    • My Untitled Blog
« Reply #4 on: November 11, 2017, 02:50:43 pm »
Interrupts on. Other interrupts are firing normally.
  • Country: cn
    • My Untitled Blog
« Reply #5 on: November 11, 2017, 02:55:52 pm »
That is where a portion of application code resides. Those are left out intentionally.
  • Country: cn
    • My Untitled Blog
« Reply #6 on: November 11, 2017, 02:58:53 pm »
I have a 8MHz clock. Changed the clock divider to ck/64 (125kHz at 8MHz system clock) but still no luck.
I have set both ADIF and ADIE, set ADIF to clear it, set ADIE to enable the interrupt.
Offline MasterT
« Reply #7 on: November 11, 2017, 03:27:57 pm »
How we supposed to know your spelling is correct?
ISR(ADC_vect) {
And what makes you think it's not fired?
  • Country: cn
    • My Untitled Blog
« Reply #8 on: November 11, 2017, 03:45:03 pm »
ISR(ADC_vect) {
I have no compiler warning or error with -Wall, which makes me believe that my spelling is correct. Missed typings on function prototype will lead to a compiler warning.
I have a breakpoint on this function (I am debugging through an Atmel ICE) but the it is not hit.
Offline HwAoRrDk
« Reply #9 on: November 11, 2017, 04:12:04 pm »
Sigh, been there. I once spent the better part of an entire day banging my head against the wall trying to figure out what was going on before I realised.
Offline Siwastaja
« Reply #10 on: November 11, 2017, 04:41:10 pm »
Try this:
ISR(ADC_vect)
    // turn on LED here. Never turn it off, so you can see if this ever fires
main()
    // turn on LED here to test it works
   delay_ms(500);
   // turn off LED here
   delay_ms(500);
   ADMUX = 0; // should be irrelevant to this problem
   // Magical code lines copypasted from some of my old random project, which works, runs ADC (ATMega640) in continuous mode and gives interrupts:
   ADCSRB = 0b00000000; // free running mode
   ADCSRA = 0b11101110; // prescaler = 64: auto trigger.
   // and...
   sei();
   while(1);
If this works, just compare what's different between this and yours.
Offline georges80
« Reply #11 on: November 11, 2017, 06:13:08 pm »
We assume you haven't powered down the ADC via the PRR0 register.
Besides... You have set the auto trigger bits to free running (000). From the datasheet:
If ADATE in ADCSRA is written to one, the value of these bits selects which source will trigger an ADC
conversion. If ADATE is cleared, the ADTS[2:0] settings will have no effect. A conversion will be triggered
by the rising edge of the selected Interrupt Flag. Note that switching from a trigger source that is cleared
to a trigger source that is set, will generate a positive edge on the trigger signal. If ADEN in ADCSRA is
set, this will start a conversion. Switching to Free Running mode (ADTS[2:0]=0) will not cause a trigger
event, even if the ADC Interrupt Flag is set.
Table 29-6 ADC Auto Trigger Source Selection
ADTS[2:0] Trigger Source
000 Free Running mode
001 Analog Comparator
010 External Interrupt Request 0
011 Timer/Counter0 Compare Match A
100 Timer/Counter0 Overflow
101 Timer/Counter1 Compare Match B
110 Timer/Counter1 Overflow
111 Timer/Counter1 Capture Event
Hint: Seems to imply that no trigger even will occur in free running mode... No trigger event means a new conversion won't be initiated.
cheers,
george.
« Last Edit: November 11, 2017, 06:18:49 pm by georges80 »
  • Country: cn
    • My Untitled Blog
« Reply #12 on: November 11, 2017, 06:47:24 pm »
Try this:
ISR(ADC_vect)
main()
   delay_ms(500);
   delay_ms(500);
   // and...
   sei();
   while(1);
Not working...
cheers,
george.
I have tried to sort-of emulate continuous mode by not setting ADATE in adc_init, but set ADSC in the end of the ADC interrupt. No luck either, there isn't even an initial conversion.
Offline Siwastaja
« Reply #13 on: November 11, 2017, 10:13:47 pm »
Look at the ADC flag register, and the conversion result register - are the flags/value updating? What do the flags say? This way you can rule out either one:
1) ADC not enabled at all, or not triggering
2) ADC converting, but interrupt not firing
If case 2, can you set a breakpoint in the interrupt vector table - or at least take a look at the binary? That would verify there is no issue in the jump table generation. (If I remember the AVR architecture correctly.)
Offline Siwastaja
« Reply #14 on: November 11, 2017, 10:34:11 pm »
Have you tried single shot first? It would narrow down possibilities.
For example, try this oneliner if you like to try random things by magic number copypasting ::):
// ADCSRB = 0 as reset value
sei();
ADCSRA = 0b11001110;
