Finally got some measurements, I’m at camp(work) for 2 weeks so I had to scrounge around to find a few things, got an burnt out LED bulb and robbed the 4.7ohm fusible resistor out of it, borrowed a meter from work (none of the meters they would let me borrow had a low mA range so I had to get the resistor for a current shunt) and did a few tests.
Running 34.9mA
Sleep with transceiver on 13.1mA
Sleep with transceiver off 8.57mA
Held in reset 6.3mA
I’m using a MC09XS3400 as my output driver and I tied what I thought was a general reset line to my reset circuit, I think this thing isn’t going to sleep when I set the wake pin to zero as the RSTB pin should also be low with the wake pin. According to the data sheet the MC09XS3400 will draw 6.5mA - 7.5mA in standby, should draw 1uA-5uA in sleep mode.
Unfortunately I don’t think I can do anymore testing till I’m home and can start removing parts and fix my errors and see if what I think is causing the problem really is the problem.
Edit: luckily I followed the datasheet’s recommended circuit and put 10k resistors on all the signal pins, just put the board into sleep mode and grounded the RSTB pin and the current went from 8.57mA to 551uA, just another small bodge wire and this thing will be running soon.
