Flash cells could leak the charge with time and get unstable. Try reading the full flash out several times, then take a binary AND of all dumps (leaked cells shits towards 1 state). How to read? - this chip has a JTAG debug port, look for some pin headers inside. Also that SRMON> prompt looks like some debug monitor console, perhaps it has some memory read functionality (try typing “help” there).
Thx, there is a 10 pin header next to the Atmel might be a JTAG but hard to check when it's a BGA chip.
regarding the SRMON I have those options:
booting...
checking firmware integrity...no firmware !
starting SRMON 0.66
SR-Monitor. Danaher Motion
[SRMON Rev 0.66 Dec 14 10:53:51 2004]
SRMON> ?
Register
<register name> [<data>] - Set register
R - Display Registers
Memory
A <start adr> - Assemble
C <range> <dest adr> - Copy memory
CLR - clear serial eeprom
CX/CUPDATE - Load Program into flash (CAN)
D<type> <range> - Display memory
DA/DI <start addr> - Disassemble
F<type> <range> <data> - Fill Memory
M<type> <start adr> - Modify memory
IO <value> - Write to Output Port
Running
B <adr> [<count>] - Set PC breakpoints
B - Display breakpoints
B - [<adr>] - Cancel breakpoints
G [<start adr>] - Go
S [<count> [<start adr>]] - Single Step
SO - Step over
[space to continue help]
SRMON>
Any suggestions how to dump to serial?
