Author Topic: LGTSDK  (Read 3240 times)
Offline dannyfTopic starter
LGTSDK
« on: May 16, 2014, 03:33:22 pm »
Interesting approach - works with gcc-avr and iar-avr.
http://www.lgtic.com/wp-content/uploads/2014/05/LGTSDK_Builder_Quick_Start.pdf
Looks to be more for the Arduino crowd, given the simplicity of the UI in the pdf file.
Offline amyk
Re: LGTSDK
« Reply #1 on: May 17, 2014, 11:50:21 am »
Good thing they didn't have a 'B' in their name. :o
Offline Psi
Re: LGTSDK
« Reply #2 on: May 17, 2014, 12:19:46 pm »
was thinking the same thing
Re: LGTSDK
« Reply #3 on: May 17, 2014, 04:35:04 pm »
I just tried it. Quite interesting.
Pros:
1) fairly modern but minimalist UI;
2) auto-detects winavr - zero configuration on my part;
3) extensive built-in drivers for avr/lgt - beats out arduino;
4) highly integrated: from device configuration, editing, build to program, all in one;
5) small download (just over 2MB + .net). No installation required.
Cons:
1) resizing of windows not quite working;
2) limited support: two devices (lgt8f88 / atmega88 and one other).
Re: LGTSDK
« Reply #4 on: May 17, 2014, 04:36:11 pm »
This is the code I ran:
// Auto generated file : 5/17/2014 12:22:39 PM
#include "allinone.h"
// Import external definitions
extern void init_modules(void);
int main(void)
// Device initialization
init_modules();
DrvGPIO_EnableOutput(B, OUT1);
// Add your code from here
while (1) {
DrvGPIO_TogglePort(B, OUT1);
return 0;
Output on the chip (simulation):
