Author Topic: Plain and Simple HDL: PSHDL  (Read 2144 times)
Offline obiwanjacobiTopic starter
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« on: November 14, 2016, 06:49:41 am »
Ran into this: pshdl.org. Have not played with it yet but I saw a presentation (from 2013) on YouTube where it suffered from some bugs - hope they are solved by now.
As a beginner in VHDL this looks heavenly.
Does anyone have experience with this?
Is the project still alive?
Thoughts?
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Online ataradov
    • Personal site
Re: Plain and Simple HDL: PSHDL
« Reply #1 on: November 14, 2016, 07:30:39 am »
This looks super sketchy. Strong redirect to on-line tool, command line one seems to be checking in with on-line and there does not seem to be a source code available despite the claims of being GPL3 licensed.
I don't want to start a holy war, but what you are looking for is SystemVerilog. It is supported (in parts) by most modern tools from actual FPGA vendors and improves quite a bit on Verilog, but still maintains simple and readable syntax.
Alex
    • Marctronix Blog
« Reply #2 on: November 14, 2016, 01:48:58 pm »
Hee SystemVerilog doesn't look bad either. Thanx!  :-+
