Author Topic: an unknown chip is looking for its data sheet  (Read 1992 times)
Offline legacy
  • Banned!
« on: February 26, 2016, 01:39:18 pm »
accidentally found, I have absolutely no idea about it  :-//
Offline relic38
Re: an unknown chip is looking for its data sheet
« Reply #1 on: March 01, 2016, 05:17:37 am »
Looks like an ASIC of some kind from AMI.  If it is an ASIC, you are not likely going to stumble onto a datasheet easily.
Offline elecman14
« Reply #2 on: March 01, 2016, 06:58:55 pm »
I believe @relic38 is correct. The part number appears to be "C2010". My initial through was the 2010 was a date code. Then again ceramic construction for a part made in year 2010 would have been strange.
After doing some digging it appears that the part was used in this calculator: http://www.calcuseum.com/SCRAPBOOK/BONUS/15634/1.htm
more info: http://www.calcuseum.com/desk_15634.html
Offline elecman14
« Reply #3 on: March 01, 2016, 07:07:13 pm »
Another random thought. AMI was bought out by on-semi in 2007 ish from what I remember. Archive.orgs wayback machine has a copy of their website before the merger. It appears that C2010 is not listed as a product so that loosely shows it probably is an asic. https://web.archive.org/web/20080115054120/http://www.amis.com/tech_resources/Product_Library.html#process_spec
Offline relic38
« Reply #4 on: March 01, 2016, 07:37:55 pm »
The logo looks strange though, not an AMI logo I've seen before.  Still I'd guess it is a prototype of an ASIC, which might explain the ceramic package.
Offline elecman14
« Reply #5 on: March 01, 2016, 07:52:45 pm »
It appears AMI changed their logo at some point in the late 80's or in the 90's. If I am reading the date code correctly the part was made in 1973. At that time ceramic construction would not have been unheard of. Not sure if it is a prototype since I am able to find a released product that use the part.
Offline legacy
  • Banned!
« Reply #6 on: March 01, 2016, 08:03:44 pm »
it's a mystery  :D
