My 48MHz comment "closer" was a bit tongue in cheek. That being said, I have always preferred Harvard architecture from a x MHz = x instructions perspective.
This mostly true for Cortex-M, but you need to keep in mind memory limitations too. For 48 MHz, you are running with 1 Flash Wait State. But sine CPU does 32-bit fetches, and most instructions are 16-bit, it all balances out. But in some degenerate cases, the code may be slower because of that. In that case, it is possible to place parts of the program into RAM.
I can live with 12MHz, would prefer higher, I'm not sure if I can enable a clock output for a set # of pulses, using PWM mode, that might work?
If you use PWM, then you can normally output up to Fper/2. So if you use a regular TC clocked from 48 MHz, then you can get up to 24 MHz. But if you use TCC clocked from 96 MHz, then you can get full 48 MHz. The problem is controlling the exact number of cycles. It all depends on your actual goal.
Back to the original problem, surely a 48MHz controller can do something useful at more than 1/50 of its specified clock speed when running regular C.
It does a lot with this code. It takes your input parameters and calculates what register it should access to toggle the required pins. And I can see it taking 50 instructions to do that.
If you want more optimal code - write more optimal code. You are using a framework - it is a compromise between the convenience, speed and code size.
I'm guessing that whatever configuration this is operating on at the moment is much slower than 48MHz, perhaps 8MHz Is
Not really, it looks like it is running at 48 MHz.
Can anyone comment on how to correct the clock configuration, when using the internal oscillator?
It is hard to tell what you have at the moment. If it is a clean ASF code, then post conf_clocks.h file. Otherwise, post your complete project.
