I've purchased two lots of Arduino pro micro clones from ebay sellers that were described as 3v3. I believe these are more correctly called Sparkfun pro micro : they have a footprint similar to the Arduino pro mini but use the 32u4 and have onboard USB.
Well, not exactly. They use the SparkFun design files (Eagle), legally, under CC-SA 4.0 International (
here at GitHub), but the Arduino Leonardo bootloader. (Arduino Leonardo has the exact same microcontroller, ATmega32u4, and basically the same schematic, just a different layout and pinout.)
So, when you program one in the Arduino environment, you select Arduino Leonardo, not SparkFun Pro Micro.
(I have programmed these on bare metal in Linux also, using avr-gcc, avr-libc, and avrdude.)
Both sets (different vendors, slightly different appearance) are what I would call 5v versions : they have 16MHz crystals and they regulate the raw input to 5v onboard for Vcc.
They are then 5V/16MHz, not 3.3V/8MHz. The difference is just one or the two components, the regulator and possibly the crystal/resonator.
ATmega32u4 has an internal oscillator calibrated to 8.0 MHz at 3.0V VCC. So, technically, you could have an ATmega32u4 running at 3.0V/8MHz without an external crystal/oscillator/resonator, but I suspect that is exceedingly rare, as it is not precise enough for USB to work. (So, without a crystal or very precise resonator, no USB.)
ATmega32u4 running off 3.3V is not stable at 16MHz; maximum clock frequency at 3.3V is 10 MHz or so. It needs 4.5V or more to run at 16 MHz.
Is there anywhere I can get one with a 3v3 regulator for less than the $20 sparkfun want ?
I've only bought the 5V/16MHz ones, as there are much more "interesting" 3.3V ones (like Teensy LC), but let's see..
I believe
this fleabay seller (Alice1101983 AKA TxHang) has the correct model. It is not the cheapest, but the dozen or so various other modules I've bought from that seller have all been as described and pictured. (Chivazhu was even better, with shipping time consistently less than two weeks to me, but has closed shop.
