Author Topic: Using HAL_SPI_Transmit_DMA() from STM32duino?  (Read 1149 times)
Offline Rudolph RiedelTopic starter
« on: January 04, 2021, 03:38:13 pm »
Hello,
after playing with my code for a couple of days now, on and off,  |O, I used PlatformIO to build a "stm32cube" project for the Nucleo-64 board with STM32F446RE I have.
I added the necessary extra code like SystemClock_Config() that STM32CubeMX generated and the SPI and DMA functions that I implemented for the STM32duino and that are using HAL and LL functions.
And damn, it works, sending data over LL_SPI_TransmitData8(), HAL_SPI_Transmit() and HAL_SPI_Transmit_DMA()
just works.
To finally come to a question, what is failing with STM32duino is the DMA interrupt.
HAL_SPI_Transmit_DMA() needs the associated IRQHandler to call HAL_DMA_IRQHandler().
So I am using this now:
void DMA2_Stream3_IRQHandler(void)
   HAL_DMA_IRQHandler(&eve_dma_handle);
And this works just fine in the stm32cube" project.
But on the STM32duino side this IRQ handler never gets called.
What extra steps do I need to make this interrupt handler work on the STM32duino side?
Offline ozcar
Re: Using HAL_SPI_Transmit_DMA() from STM32duino?
« Reply #1 on: January 04, 2021, 05:46:40 pm »
Perhaps you have to add extern "C" to your interrupt routine definition.
If that does not work, you may be better off asking on www.stm32duino.com .
The following users thanked this post: Rudolph Riedel
« Reply #2 on: January 04, 2021, 06:10:43 pm »
That was exactly what was missing, thanks!  :) :)  :-+
extern "C" void DMA2_Stream3_IRQHandler(void)
This is only required for this one, the callback function HAL_SPI_TxCpltCallback() is fine without it.
And I am not even using C++, the file is named .cpp since the Arduino classes require it.
Or well, maybe there is annother way to use for example the SPI class from a .c file but it has been a while since I looked
for a solution to this.
