Call me weird, but I don't even like to use the stdint.h as I like to use the least amount of code I'm unfarmiliar with as possible. Things like uint8_t I would just instantiate directly (volatile unsigned char).
As for TTCR/TIMSK/TCNT... these represent the registers in the IC and the values that are stored in them. Your AVR IC at its lowest level is not a general purpose device (say like an FPGA) but rather dedicated hardware which needs to be configured prior to use. Things like interrupts, timers/counters, UART, ADC etc. need to be set-up by writing values to specific registers in the chip. Download the .pdf datasheet (full, not summary) for your device from Atmel's website, and read the ENTIRE thing. This will explain everything for you.
Until you get the hang of things, I'd highly recommend starting out with a simple reference design (blinking an LED). Make sure you understand what each line of the example code is doing. Once the light turns on (literally and metaphorically) you will be ready to begin your own adventure into the world of microcontrollers. May the force be with you!
