Hello all
I tried to make this modification on my ISP mkII, but have problem's
I use
-lm317
-2 x 0.1uF
-360 ohm
-220 ohm
I connected everything like dave in his video tutorial.
When I connected to USB, I get voltages:
5.1V and 2.83V (switch on/off and 5/3.3 work OK )
I also try to read this voltages in AVR Studio 5(target voltages), which are the same.
But then I want to connect on chip, so I tried on xmega16a4. Before I connect I first try to connect via power supply to ensure that all work OK. And it was, I can read xmega, set fuses....
Then I turn off power supply and try to connect ISP, with this modification. After I connect to chip and try to read, voltage drop to 1.5V. This also show in avr studio as target voltage(which we all know that it's too low)->1.5V
Any ideas how to solve my problem?
