The CLion C/C++ IDE from JetBrains
https://jetbrains.com/clion is based on the IntelliJ/IDEA core: it is one of a number of variants supporting different languages. The 2018.3 Early-Access Preview released on Sept 19th adds initial support for remote target operation. The IDE itself and the project source code live on the host machine (PC, laptop) and are downloaded to the target for build, compilation and debugging, using the host as the debug UI. At the same time, the target header files etc., are uploaded to the host, so they can be used to provide IDE 'intelligence' (e.g. showing function parameters, auto-completion hints).
Currently the host has to be Unix-like (Linux or Mac), and the target has to be Linux, with installed supported compiler, debugger, make, rsync, & CMake. I have used it to develop on a Raspberry Pi running Raspbian, from a Mac host, and the experience has been OK, albeit still with a few rough edges.
The Early Access Program
https://www.jetbrains.com/clion/nextversion/ is free to join (CLion is normally annually licensed, for a range of prices including free, depending on the customer & application) so if you feel inclined to try it out, give it a go!
Disclaimer: I am a JetBrains customer (personal license for the full suite) but not otherwise associated with the company
