> That goes out of the window if you need a specific form factor, thermal management, interfaces (*), or other special requirements like a centered boot logo, etc.
Well, yeah, obviously you design to avoid all of that?!
Like, you leave enough space that you could easily fit in any reasonable future SBC, probably don't mount the board directly, don't do a tight thermal design, avoid specialized or likely to be deprecated interfaces, ... and forget about a boot logo? ;-)
> Also keep in mind that a module relies on making contact reliably with a carrier board. Reliability of interconnects is not a given and are best to be avoided where possible.
Well, yeah, depends on the application, of course, but obviously you don't want to use unreliable connectors ...
> You'll see that this is near impossible due to technology progressing and new interfaces replace the older ones. For example: try to replace a module with a Sata interface with a modern day module.
Well, yeah, there is a reason why I mentioned ethernet and RS232 ;-)
As for storage, I guess I would consider that part of the "SBC assembly"? I mean, all of this obviously depends on the application, there obviously are many applications that really aren't a good fit for this approach, but it's an option to consider that can considerably reduce design effort where the limitations of the approach don't matter much.
