Author Topic: Best MCU (or FGPA) for signal processing (beginer) ?  (Read 2338 times)
Offline dasloloTopic starter
  • I saw wifi signal once
« on: April 23, 2018, 06:24:46 am »
And the purpose of this is to do signal recognition.
For N input such as noise, V/time I am testing a theory that I can have a self contained device recognize machine.
What do you folks recommend that's either easy to program or very well documented to dive into?
« Last Edit: April 23, 2018, 06:48:39 am by daslolo »
nine nine nein
Offline andyturk
Re: Best MCU (or FGPA) for signal processing (beginer) ?
« Reply #1 on: April 23, 2018, 02:16:56 pm »
Maybe better to do your first (beginner) signal processing on a conventional computer. Use Matlab, C, or whatever. That allows you to get right to the heart of whether your "algorithm" works before having to deal with mcu/fpga tooling.
All you need to get started is some pre-recorded data that looks sufficiently close to what your actual sensors will provide.
The following users thanked this post: nctnico
Offline SiliconWizard
« Reply #2 on: April 23, 2018, 02:19:34 pm »
I completely second that!
That said, maybe the author has already gone through this process. If so, it's hard to suggest a platform without knowing more about the algorithms, the type of analysis/transforms used, and the targetted sample rate.
Offline rstofer
« Reply #3 on: April 23, 2018, 02:25:04 pm »
Definitely Matlab...
Analog Devices Blackfin is intended for DSP as is the SHARC which has floating point hardware.
If you really want to get your hands dirty, most modern FPGAs have DSP hardware components.
https://www.xilinx.com/video/fpga/artix-7-fpgas-for-dsp.html
Offline FlyingDutch
« Reply #4 on: April 23, 2018, 05:08:28 pm »
Hello,
you didn't write what signals are you going to process? If you mean audio signals then STM32-Nucleo has DSP functions built-in. I mean two series of STM32Nucleo: STM32-F4 and STM32-F7 .The first family is based on ARM Cortex-M4 and second on ARM Cortex-M7);
Both families have FPU and DSP blocks. See link:
http://www.st.com/en/microcontrollers/stm32f777vi.html#sw-tools-scroll
There are STM32 Audio processing SW library and other tools for audio processing:
http://www.st.com/en/embedded-software/stm32-audio100a.html
https://dspconcepts.com/st
As one colleague said - most of modern FPGA families have hardware multipliers and DSP blocks (there are also some free IP Cores for DSP: CORDIC, Filters, Calculus transforms for example FFT). For example Xilinx Spartan3E and Spartan6 families have DSP blocks (these are cheap families of FPGA).
If you mean processing vision signals you should take into consideration more powerful families of FPGA (vision processing systems) or strong GPU with CUDA or OpenCL technology on the PC platform.
BTW: "signal recognition" is also related to "Machine Learning" (or AI) and this is a bit different story then general DSP.
For "pattern recognition" (not only signals) you can use some matured algorithms. For example:
1) SVM (Support Vector Machine) - it has implementations in Matlab and C languages
https://en.wikipedia.org/wiki/Support_vector_machine
https://www.mathworks.com/help/stats/support-vector-machine-classification.html
The SVM algorithm is often used together with PCA (Principal Component Analysis). PCA is used to determine portions of pattern carrying most of variability (It is done before SVM). See link:
https://en.wikipedia.org/wiki/Principal_component_analysis
2) Neural Networks (today there are many types of it) - also implementation in Matlab, C++, Python
https://www.mathworks.com/products/neural-network.html
Kind Regards.
« Last Edit: April 23, 2018, 06:28:29 pm by FlyingDutch »
Offline BBBbbb
« Reply #5 on: April 23, 2018, 07:44:22 pm »
I do hope all those AI (well mostly CNN) chips being developed by many bigger players will come to the masses soon. That will be fun in.
« Reply #6 on: April 23, 2018, 11:34:24 pm »
The beauty of NN is that once trained they require very little juice. The difficulty of NN is training so let's see what that would take:
Bath the sensors in room, turn off the fuse box and all the machines, tell the NN this is ambient noise and sit there for a days to handle night and day time ambient people activity. Then come back in, turn on the fuse box and tell the NN this is the fuse box with ambient noise, let it iterate for a while. Same for motor #1, motor #2, both motors. continue with all the permutations and then take off the training wheel and let the NN figure out what's on.
 |O
There's got to be a better way that doesn't require baby sitting or sensing the EM field in some faraday cage.
nine nine nein
Offline BBBbbb
« Reply #7 on: April 23, 2018, 11:50:15 pm »
 |O
For your case parametric is the way to go, not NN.
I was just having a wet dream about those NN chips being available soon. Anyways without a possibility to train the NN on your PC (and use the GPU) and then transfer the knowledge to the chip it wouldmake things harder.
I can't remember if it was on the AMP hour or embedded.fm that they talked about this company that does signal processing of the current and voltage data gathered at your service panel and can determine what is on and off. Maybe I'm wrong, but it could have been that they said they only monitor the input lines... Really cool stuff...
« Reply #8 on: April 25, 2018, 08:38:59 am »
Still, NN hardware for you https://www.amazon.com/Intel-NCSM2450-DK1-Movidius-Neural-Compute/dp/B076751BN8/ref=sr_1_2?ie=UTF8&qid=1524645314&sr=8-2&keywords=Intel%C2%AE+Movidius%E2%84%A2+Neural+Compute+Stick
How do I approch parametric? Or SVM with code? I see these graphs and lines and then formulas and my mind good *poof*
nine nine nein
Offline BBBbbb
« Reply #9 on: April 25, 2018, 03:50:52 pm »
So you want sound analysis in a room if I understood correctly.
Like some mentioned previously, I'd get it recorded and than just play around with different techniques in Matlab. Close to no code needed, but you need to know the basic theory behind the methods. I'm sure you'll find any technique you want to try usually in form of a single function in Matlab's signal processing toolbox. There's a full version of Matlab available for free for one month. Also Matlab can (usually) spit out C code for what you do, but I haven't found it to be too good...
First try to acquire good signal (might not be as easy as you think). You'd probably need some preprocessing (filtering...) prior to using classification.
Regarding the methods to use... well it depends, if you're lost I'd recommend going through some MOOC on signal processing and classification to get some ideas.
« Last Edit: April 25, 2018, 03:55:17 pm by BBBbbb »
