Author Topic: MachXO2 External SPI Flash device  (Read 1748 times)
Offline ale500Topic starter
« on: November 12, 2016, 04:57:58 pm »
Hei,
I'd like to use an external SPI flash memory with a MachXO2 FPGA, but not for the configuration but for custom data that has to be pre-programmed.  I see that one can program such a flash memory to contain configuration data using the built-in programmer. I'm looking for ways to in-circuit pre-program such a memory. Could one use the built-in programmer for such a task (let's suppose that the flash device is connected to the "reserved" pins for SPI flash) ?
Does someone has any experience ?
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: MachXO2 External SPI Flash device
« Reply #1 on: November 12, 2016, 05:39:54 pm »
If by built-in programmer you mean the normal JTAG programmer, the way this typically works is that the programmer software soft-loads a trivial bitmap which links the JTAG pins to the SPI device to allow programming using SPI protocol over the JTAG pins.
Should be possible to make it program a device that contains data other than a programming bitmap.
You can also buy Microchip SPI flash devices preprogrammed from Microchip Direct, though their devices ( ex SST) are rather more expensive than some of the competition from ISSI or Spansion.
Day Job: Mostly LEDs
« Reply #2 on: November 18, 2016, 05:28:05 pm »
I think I'd program the device before I solder it :), and then just make some small core that can receive a new image, if needed., thanks for the suggestion. I'm going to do 2 boards, so programming the chips beforehand seems convenient.
