I have >10 PC's with identical control PCB boards to modify. 115200 baud is fast enough. Just want to use a very easy to find USB to USB cable(like those used to connect a PC to a printer) to connect to the modified control board.
Looks like there are two recommended best choices CP2102 and FT232RL
Which chip has the best easy to get it to work with no crashes/it just works driver?
Both are good, The CP2102
N is newest version of CP2102, but the FT232RL is now quite old. The FT231X is probably a more modern choice.
Get an Eval board for each one, and try them.
Does the package matter ? Will you be making your own PCB, or buying a interface module ?
If buying an interface module, you need to consider form factor and cable used.
USB-A is cheap in a module, but those cables are now less common.
eBay has many CP2102 modules, tho the eBay FT231X modules seem to be very silly prices - maybe they target someone who mistakes currency conversions ?
eBay has better prices on the older FT232RL parts
