Not to be closed minded here but I am sort of hovering the TLA2021, or actually probably the TLA2022 because they are the same price and the 2022 has a PGA which may help somewhere down the line. As opposed to the INA226, this is only a 12bit, and less features, but to be honest, it seems like it would serve the job? We just don't need extreme accuracy and I have to fight to hold the budget down.
I did want to ask on these chips, one thing we need or want is the entire circuit wakes up with an input on the ADC, indicating something has started running. However, I need to determine if this chip can wake up from sleep mode in that way, but regardless the chip power consumption as 'active' is only 150uA so we can budget for that if we must.
