Author Topic: Bluetooth Audio using RN42 Through FPGA  (Read 3042 times)
Offline redyjr4Topic starter
« on: February 24, 2024, 08:57:04 pm »
Hello,
I am working on a project where I connect a bluetooth speaker to an FPGA using the following component: https://digilent.com/shop/pmod-bt2-bluetooth-interface/
I am working to configure this device, and I am wondering whether the RN42 can support Bluetooth audio?
Thanks!
Offline eosti
Re: Bluetooth Audio using RN42 Through FPGA
« Reply #1 on: February 24, 2024, 09:17:40 pm »
According to the datasheet (https://ww1.microchip.com/downloads/en/DeviceDoc/rn-42-ds-v2.32r.pdf) of the onboard chip, it does not support any audio profiles in the built-in stack. However, it does appear that you may be able to implement your own profile using Host Controller Interface (HCI) mode? I don't know what that'd entail, but that would probably be the best bet.
Offline Zipdox
« Reply #2 on: March 04, 2024, 09:50:26 am »
It's not recommended for new designs and has Bluetooth 2.1, which is ancient. It's safe to say that this is a futile endeavor. Is suggest getting a BM83. Or an nRF5340.
