Hello
I need someone with C++ knowledge. My knowledge in C++ is limited.
I rewrote the GfxUi in the main.cpp file and it works, but I don't get it compiled successfully, when I try to make a Header and cpp File.
The Original File is right here
https://github.com/Bodmer/DarkSkyWeather/blob/master/examples/TFT_eSPI_weather/GfxUi.hMy new 1024 x 600 display does not work with the Super tolle work from
https://github.com/Bodmer/TFT_eSPIMr. Bodmer did a great Job with graphics and sprites in the MCU world
#define LGFX_USE_V1
#include <LovyanGFX.hpp>
#define SCREEN_HD
//#define SCREEN_NORMAL
#ifdef SCREEN_HD
#define SCREEN_W 1024
#define SCREEN_H 600
#endif
#define FS_NO_GLOBALS // Avoid conflict with SD library File type definition
#include <FS.h>
// JPEG decoder library
#include <JPEGDecoder.h>
class GfxUi {
public:
GfxUi(LGFX * tft);
void drawBmp(String filename, uint16_t x, uint16_t y);
void drawProgressBar(uint16_t x, uint16_t y, uint16_t w, uint16_t h, uint8_t percentage, uint16_t frameColor, uint16_t barColor);
void jpegInfo();
void drawJpeg(String filename, int xpos, int ypos);
void jpegRender(int xpos, int ypos);
private:
LGFX * _tft;
uint16_t read16(fs::File &f);
uint32_t read32(fs::File &f);
GfxUi::GfxUi(LGFX *tft) {
_tft = tft;
void GfxUi::drawProgressBar(uint16_t x0, uint16_t y0, uint16_t w, uint16_t h, uint8_t percentage, uint16_t frameColor, uint16_t barColor) {
if (percentage == 0) {
_tft->fillRoundRect(x0, y0, w, h, 3, TFT_BLACK);
uint8_t margin = 2;
uint16_t barHeight = h - 2 * margin;
uint16_t barWidth = w - 2 * margin;
_tft->drawRoundRect(x0, y0, w, h, 3, frameColor);
_tft->fillRect(x0 + margin, y0 + margin, barWidth * percentage / 100.0, barHeight, barColor);
// Bodmer's streamlined x2 faster "no seek" version
void GfxUi::drawBmp(String filename, uint16_t x, uint16_t y)
if ((x >= _tft->width()) || (y >= _tft->height())) return;
fs::File bmpFS;
// Check file exists and open it
// Serial.println(filename);
// Note: ESP32 passes "open" test even if file does not exist, whereas ESP8266 returns NULL
if ( !SPIFFS.exists(filename) )
Serial.println(F(" File not found")); // Can comment out if not needed
return;
// Open requested file
bmpFS = SPIFFS.open(filename, "r");
uint32_t seekOffset;
uint16_t w, h, row, col;
uint8_t r, g, b;
if (read16(bmpFS) == 0x4D42)
read32(bmpFS);
read32(bmpFS);
seekOffset = read32(bmpFS);
read32(bmpFS);
w = read32(bmpFS);
h = read32(bmpFS);
if ((read16(bmpFS) == 1) && (read16(bmpFS) == 24) && (read32(bmpFS) == 0))
y += h - 1;
_tft->setSwapBytes(true);
bmpFS.seek(seekOffset);
// Calculate padding to avoid seek
uint16_t padding = (4 - ((w * 3) & 3)) & 3;
uint8_t lineBuffer[w * 3 + padding];
for (row = 0; row < h; row++) {
bmpFS.read(lineBuffer, sizeof(lineBuffer));
uint8_t* bptr = lineBuffer;
uint16_t* tptr = (uint16_t*)lineBuffer;
// Convert 24 to 16 bit colours using the same line buffer for results
for (uint16_t col = 0; col < w; col++)
b = *bptr++;
g = *bptr++;
r = *bptr++;
*tptr++ = ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
// Push the pixel row to screen, pushImage will crop the line if needed
// y is decremented as the BMP image is drawn bottom up
_tft->pushImage(x, y--, w, 1, (uint16_t*)lineBuffer);
else Serial.println("BMP format not recognized.");
bmpFS.close();
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t GfxUi::read16(fs::File &f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t GfxUi::read32(fs::File &f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
