Author Topic: Code map in MPLAB X IDE - being thick  (Read 1594 times)
Offline fcbTopic starter
    • Electron Plus
« on: October 15, 2017, 01:29:52 pm »
I'm writing some fairly complex assembler (my preferred language) and I'm being thick.
How do I see the listing of the actual code vs. memory location? I'm sure this was trivial on MPLAB 8.92.
Offline cv007
Re: Code map in MPLAB X IDE - being thick
« Reply #1 on: October 15, 2017, 02:58:23 pm »
Go into your project folder- then under dist/default/production you will find a .lst file among others (at least that's where to find them for 8bit pics).
edit- it appears I'm the thick one, I missed that you were coding in assembler (mpasm I presume). Disregard.
« Last Edit: October 16, 2017, 03:16:26 am by cv007 »
The following users thanked this post: fcb
Offline NorthGuy
« Reply #2 on: October 15, 2017, 06:13:30 pm »
Window->Debugging->Output->Disassembly Listing File
    • Electron Plus
« Reply #3 on: October 16, 2017, 08:57:16 am »
Brilliant! Exactly what I was looking for. Thank you.
