Author Topic: rotary encoder in c (stm32)  (Read 2283 times)
Offline m0p
« on: July 03, 2017, 07:51:26 am »
Hi!
Im trying to get a rotary encoder working but its just to advanced for me...
This is the code i tried to write but its not the right way to do it...
And i just dont know how to think...
Can someone help me in the right direction here?  :)
          int rot = (0x0000);
while(1)
       if (!GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_1))
       rot = 1;
       rot<<=1;
       if (!GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_2))
              rot = rot + 1;
              rot<<=1;
              rot = rot + 1;
              rot<<=1;
                    rot = rot + 1;
                    rot<<=1;
           if (rot == 1 || rot == 7 || rot == 8 || rot == 14)
           a[0] = a[0] + 34360;
           if (rot == 2 || rot == 7 || rot == 8 || rot == 14)
                       a[0] = a[0] - 34360;
           rot = 0;
Offline voltsandjolts
Re: rotary encoder in c (stm32)
« Reply #1 on: July 03, 2017, 07:55:46 am »
Welcome to the forum.
This topic has been discussed quite a lot. You can use the google search term "rotary encoder site:eevblog.com" if you don't like the forum built-in search.
Example:
https://www.eevblog.com/forum/projects/easy-rotary-encoder-implementation-good-easy-to-implement-code/
Offline MarkF
« Reply #2 on: July 03, 2017, 09:13:58 am »
I used the attached application note for PEC11 encoders with their suggested pull-up and filter shown in the datasheet. The assembly code in the app note can be accomplished with just a few lines of C code.
