Author Topic: brainchip AKD1000  (Read 1822 times)
Online ali_asadzadehTopic starter
brainchip AKD1000
« on: September 20, 2021, 06:56:13 am »
I was searching keil packs, and the brainchip AKD1000 catch my attention, It seems we would get some Cortex M4 part with some accelerators for doing AI in IOT devices.
But I could not find any datasheet or user manual yet,
This is their website,
https://brainchipinc.com/
Do you know any info on this core or company?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Online iMo
  • Country: pm
  • It's important to try new things..
Re: brainchip AKD1000
« Reply #1 on: September 20, 2021, 09:21:05 am »
Each Akida NSoC has effectively 1.2 million neurons
and 10 billion synapses, representing orders of
magnitude better efficiency than other neural
processing devices on the market.
How all those neurons and synapses fit into that chip??
« Reply #2 on: September 20, 2021, 06:59:48 pm »
I don't know maybe a typo, Also they say it has USB3.0, PCIe  etc...
Offline uer166
« Reply #3 on: September 20, 2021, 09:00:08 pm »
Probably not a single chip, but
scalable solution utilizing a built-in serial chip-to-chip connectivity to allow up to 64 devices to be arrayed as a single solution.
With 64 chips that number might be vaguely achievable?
Offline WatchfulEye
« Reply #4 on: September 21, 2021, 12:13:04 am »
The individual components may be quite small. The technology appears to be a variant of spiking neural network, where instead of RAM/multiply-add units for storing data and performing the matrix multipications digitally, the technology is effectively analog - albeit using pulse frequency modulation (hence the "spiking" name) rather than a continuously varying voltage.
The basic operation of a neuron can be modeled as the dot product (a∙b) of a array of pulse modulated inputs (a) and an array of pre-programmed memristors (b). The current delivered by each input is given by aibi, where ai is the pulse frequency of input i, and bi is the programmed conductivity of memristor i. By connecting all inputs to a summing capacitor, the dot product operation is complete. So, you can have a neuron with 1k inputs consisting of a capacitor, sense amp/pulse frequency modulator and 1000 memristor cells which receive inputs from 1000 other neurons. The memristor cells can be manufactured on the scale of flash memory cells, and multilayer manufacturing (similar to 3D NAND flash) has also been demonstrated, so 10 G memristor cells on one chip doesn't seem completely unreasonable.
The following users thanked this post: ralphrmartin
Offline MadMayHam
  • Country: sg
« Reply #5 on: October 30, 2021, 12:33:40 pm »
Hi all, you can actually buy the development kits with the actual production version of the Akida 1000 processor in silicon at https://shop.brainchipinc.com/ .
« Reply #6 on: October 31, 2021, 07:22:13 am »
MadMayHam are you working there?
