Author Topic: Bugs running MCS BASIC-52 on 8052  (Read 16097 times)
Offline free_electron
    • SiliconValleyGarage
Re: Bugs running MCS BASIC-52 on 8052
« Reply #25 on: August 13, 2020, 06:11:51 pm »
you have not seen what this thing can do until you instantiate the oregano designs 8051 core, a ram and a rom in an Altera FPGa and clock it at 400 MHz ....
That is one speedy basic machine !
Offline JohnnyQuest1111
« Reply #26 on: August 14, 2020, 07:48:30 am »
All that crazy speed for MCS-BASIC and the slowest link is the serial port ... if the program prints output ... or the human operator ... if the program is *WAITING* for user input.  :)
I can appreciate the fun of the project.
At 400MHz, what applications could this blazing fast MCS-BASIC support?
Peace and blessings,
JQ
Offline 0db
  • Country: zm
« Reply #27 on: August 14, 2020, 08:02:48 am »
400Mhz? on which fpga?
Offline brucehoult
« Reply #28 on: August 14, 2020, 08:22:48 am »
This thread is very interesting. A few days ago I ordered a handful of 65C02 chips (and 65C22 VIA), some 32Kx8 SRAMs, some 32Kx8 EEPROMs (and a programmer) and a bunch of latches, inverters, 2 input NAND and NOR gates, 8 input NAND gates. Planning to play around with all this stuff on a breadboard.
No reason not to play with the same stuff with 8051 or other old CPUs also. I already had plans to try the SRAM on the ATMega2560 eternal bus (the 8 bit latch chip is needed for this, to demultiplex the data bus and LSBs of the address)
A cool thing about the 65C02 is it's fully static, so can be run at 0 Hz and stopped or single stepped by hand. Does that apply to 8051 also? I think the Microchip ones are? And also Z180 but not Z80?
Offline retrolefty
« Reply #29 on: August 14, 2020, 09:20:50 am »
 Z-80 was always fully static and also had support for auto refresh of the DRAM of the day.
Offline brucehoult
« Reply #30 on: August 14, 2020, 10:12:11 am »
I don't believe the NMOS ones were.
« Reply #31 on: August 15, 2020, 06:31:26 pm »
JQ
i stripped the uart and converted that into a ftdi245 port. it was speedy ...
The oregano core is one of those 'turbo' cores. Most instructions process in a single clocktick. It is free. You can get the verilog. I ran it on a Cyclone 5 i believe. PLL was set to 420MHz. it's been a while. i mapped the ram and rom in the FPGA so nothing external was needed. the rest were simply GPIO pins.
« Reply #32 on: August 18, 2020, 10:12:45 am »
Beautiful!
I used to be an FAE for XILINX. Was taught all about the parts and how they work, tools and all. But I never had the time to do anything like that on my own.
JQ
