Whenever you need to change the microcontroller family, will the pickit firmware be reinstalled?
"Now Downloading new Firmware for target device"
PICkit3 has the PIC24FJ256GB110 on its board, and its datasheet says its durability (minimum) is only 10,000 write / erase cycles.
"Flash Program Memory: 10,000 erase/write cycle endurance (minimum)"
So if I want PICkit3 to have the durability of a PICkit2, do I have to buy a PICkit3 for every family I use?
Of course, because if every time I change the family, PICkit3 burns the flash memory again, the countdown of its lifespan will be triggered.
Or should I avoid buying PICs from different families?
