I believe exceptions are not supported for C++ programming using the g++ compiler with the Atmel AVR family. In the limited amount of embedded programming I have done, it is not something I like to do. Exceptions allow you to back out of many levels of function calls quickly, but I like avoiding too many levels of function calls anyway. Function calls can chew up the very limited RAM in embedded processors, and also chew up time, so I have often limited myself to no more then 4 levels of function calls maximum. I tend to more of a flat level State approach to programming and instead of throwing an exception, I just change to a different State.
So say I have a watch dog timer for a communications process. If the watch dog timer trips indicating that the handshake has totally stalled, instead of throwing an exception, I would just change a State byte so that next time the main loop checks for the current state, it will go to a State that resets the communications. In embedded programs, I try and write all loops so the code can never get stuck in a loop. I make sure that every State function will run very quickly, even if that means to complete a task, the State function has to be run many times.
There are probably better approaches, but this method works for me.
Richard.
