Author Topic: C handling strings \n cubeide  (Read 1252 times)
Offline strawberryTopic starter
  • Country: lv
« on: May 27, 2023, 10:04:45 am »
"◙ \n"
1:0x0A ASCII
2:\n doent work because \ is escape char
Offline DavidAlfa
Re: C handling strings \n cubeide
« Reply #1 on: May 27, 2023, 11:30:09 am »
What?
Offline brucehoult
« Reply #2 on: May 27, 2023, 11:54:43 am »
The escape character is there exactly so that you get 0xA instead of the normal 'n' = 0x6E.
The following users thanked this post: boB, mikerj
Offline DavidAlfa
« Reply #3 on: May 27, 2023, 12:06:50 pm »
If you really want to show "◙ \n", then use "◙ \\n" , special characters need to be escaped.
So \\ will print \. A single \ will escape the next char, but you already knew it!
https://www.w3schools.com/c/c_strings_esc.php
https://www.geeksforgeeks.org/escape-sequence-in-c/
« Last Edit: May 27, 2023, 12:08:34 pm by DavidAlfa »
  • Country: lv
« Reply #4 on: May 27, 2023, 12:09:42 pm »
for some reason scanning string doesn't return true
if (char == '\n')
Offline brucehoult
« Reply #5 on: May 27, 2023, 12:41:21 pm »
if (char == '\n')
It would help if you showed a complete but minimal program.
Compilers, as a rule, are not buggy, so with 99.99% probability what you are doing is not what you think you are doing.
As a stupid example:
void foo(char char)
  if (char == '\n');
     printf("char is a newline\n");
« Last Edit: May 27, 2023, 12:45:57 pm by brucehoult »
The following users thanked this post: agehall
Offline hans
« Reply #6 on: May 27, 2023, 01:00:48 pm »
I would be cautious in mixing unicode with char in regular C code. Normally a string is a sequence of 'char' type, but in e.g. UTF8 encoding, one character can be 1 or more bytes long. Where only if a byte of a string is lower than 0x80, it means its a char from the standard ASCII set: https://en.wikipedia.org/wiki/UTF-8#Encoding
E.g.: https://godbolt.org/z/671PKrzGe
But, there are many other types of unicode encoding sets. It depends on your text editor how the unicode characters are saved in the file.
Also don't confuse char and strings. And maybe post a bit more because at present the question statement is a riddle.
The following users thanked this post: MMMarco
Offline DavidAlfa
« Reply #7 on: May 27, 2023, 02:59:29 pm »
Better you start posting proper code instead few lose fragments!
Offline Doctorandus_P
« Reply #8 on: June 10, 2023, 04:06:45 pm »
It would be nice if you added your intention or comprehension of what it is you suppose or want it to do.
Offline DavidAlfa
« Reply #9 on: June 10, 2023, 07:16:14 pm »
I very much doubt it's a compiler / IDE problem.
You might have run into thinking it's ASCII, so 1 byte for each character, 4 bytes including termination.
But that unicode string is written as { 0xE2, 0x97, 0x99, 0x20, 0x0A, 0x00}, so 6 bytes, char[4] is the newline.
Anyways there's no reason it wouldn't detect '\n'.
This works as expected, finding it at char[4];
char msg[] = "◙ \n";
uint8_t find_newline(char * s){
  uint8_t c=0;
  while(*s){
    if(*s++ == '\n')
      break;
    c++;
  return c;
« Last Edit: June 10, 2023, 07:38:39 pm by DavidAlfa »
