Basically Zynq = Artix7 fabric plus dual-core ARM. If your designs would benefit from ARM processors that are tightly coupled with FPGA logic and external memory, then Zynq might be appropriate.
You might like to look at the kinds of things that are possible, and see if they are relevant to your situation. Look at the MicroZed board, the Red Pitaya scope+, and the IP primitives that are supplied by Xilinx.
We cannot advise you what your designs require; sorry!
