Author Topic: Why Arduino users so agressive?  (Read 63450 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Why Arduino users so agressive?
« Reply #400 on: September 03, 2019, 07:57:54 pm »
But how about Rust on Arduino?
 ;D
tin the leads ;)
Offline techman-001
  • Electronics technician for the last 50 years
    • Mecrisp Stellaris Unofficial UserDoc
« Reply #401 on: September 03, 2019, 08:15:01 pm »
FORTH is a very low level stack based programming language yet at the same time a very high one. It's a bit of a weird one.
Examples here: https://learnxinyminutes.com/docs/forth/
A FORTH interpreter and compiler is so small it can run on the target rather than being cross compiled. Literally you can write your code on an AVR for example on the actual device with a serial terminal.
It is however immensely powerful and it's possible to do some cool tricks like sandboxed code.
How to make an Arduino good: http://amforth.sourceforge.net/TG/recipes/Arduino-HelloWorld.html  (there back on topic  :-DD)
Or for Forth on STM32 instead of X86 or AVR see my sig below.
Arduino users please don't get all aggressive now ....  there back on topic  :-DD
« Reply #402 on: September 03, 2019, 08:18:15 pm »
Excellent stuff :-+
I used to get copies of TCJ back in the 90s. Brad Rodriquez ran a series on building FORTH interpreters from scratch. Learned a lot. Then got distracted by common lisp  :-DD
Articles here: https://www.bradrodriguez.com/papers/index.html
TCJ here: https://archive.org/details/the-computer-journal
TCJ was about the trailing edge of computing. Doing less with more. tggzzz would like it if he doesn't already know about it.
Offline SiliconWizard
« Reply #403 on: September 03, 2019, 08:24:27 pm »
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
« Reply #404 on: September 03, 2019, 10:40:40 pm »
Forth also runs on the STM8 family, and here is a sub-$2 thermostat board with 3 7-segments, 3 push buttons, a temperature probe, and a relay:
https://github.com/TG9541/stm8ef/wiki/Board-W1209
Currently developing embedded RISC-V. Recently STM32 and STM8. All are excellent choices. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
Offline techman-001
« Reply #405 on: September 04, 2019, 07:26:47 am »
Excellent stuff :-+
What a blast from the past with TCJ  :clap:
The March/April 1995 edition centerfold is the Rockwell 65F11 which I worked with in 1987. It had Forth pre-loaded in internal ROM from the factory. That era was my heyday in embedded and incredible fun  :-+
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #406 on: September 04, 2019, 08:33:23 am »
: 1 2 ;
Offline techman-001
« Reply #407 on: September 04, 2019, 10:10:32 am »
I like STM8, it's cheap, has lots of peripherals, is big endian and e4th Forth is very nice.
If I wasn't so invested in STM32 I'd probably be using STM8 myself.
Offline legacy
« Reply #408 on: September 04, 2019, 01:52:17 pm »
is there any Forth rom for hc11? My handyboard was shipped preoloaded with two ROMs: BUFALO and IC (by MIT).
Offline techman-001
« Reply #409 on: September 04, 2019, 02:03:50 pm »
Sure!
The HC11 is one of my original all time favorite MCU's, I LOVE Motorola 6800 Assembly, it's as smooth as silk!
The HC11 was targeted by a few Forth writers way back, have a look at http://forth.org/library/eforth_SOC/eforth_SOC_source/eForth1/68eforth.zip
Offline Petrary
  • Country: in
« Reply #410 on: September 14, 2019, 10:54:21 am »
Can you be more specific so that we can try to figure out things?
